95mm silicone reducing elbow
berg
Does anyone have any ideas on where i can find a 95-76mm (3.75"-3") 45 degree silicone elbow in Black
Ive looked on every silicone hose place i can think of including google and ebay search
Closest ive found is 90 degree on ebay which is no good
Most top places go from 90 straight to 102 and dont list 95 at all
My 90mm throttle body has a 95mm outer diameter just to make things harder :(
I think you either need to have a 1 off hose made or modify your set up.
You could use this size hose and have a sleeve turned to fit to the throttle body to raise the diameter up
to the hose size, or you could add to the outside of the intercooler pipe to raise that size up possibly
Or have the bend you need fabricated in Aluminium.st/st tube then use straight couplers at each end
http://www.ebay.co.uk/itm/TOG-3-4-INCH-76-102MM-45-DEGREE-SILICONE-HOSE-REDUCER-BEND-ELBOW-BLUE-125MM-/111119995506?hash=item19df449272
