Click click click! Non starter!!
cloudder
My Supra doesn't get used too much these days, but last weekend I used it and again this Monday to go to work (50 miles). Anyway got back from work left it in the drive and then 10 minutes later I went to start it and all I got was a loud noise like Woody Woodpecker at work on the starter! I checked the battery and the charger said it was 90 % good. I,ve pulled the starter and swapped out the solenoid contacts tonight, but Woody is still there, no change. All dash lights seam OK. Any ideas??
Andy
One thought, can I run a temporary wire from the small terminal on the solenoid to the battery positive terminal ( perhaps via a switch?) to see if the starter would turn the engine over? I am thinking if putting power on that terminal, this should pull the solenoid shut and give battery power to the starter and therefore it should turn over but not fire? Or am I over simplifying it or missed something?
I haven't got one. I asked a couple of neighbours last night but they didn't have one. Could it be the battery ? The condition indicator is showing a green tint and when i connect my battery charger it says it is Ok, but I can't say how accurate it is, but it is a few years old now. When I turn the ignition key to starter it sounds like there's a hammer drill in the starter. I f I can find a meter what would be a good reading across the battery terminals or where else should I check the voltage?
Had the click click click on both my supra's turned out to be battery.
If you have a set up jump leads and to save buying a meter, disconnect the battery and attach the leads to the terminals and start the car like how you would jump any other car. Should tell you straight away if it is battery or not. That is how I diagnosed mine
Just because the battery is showing green does not mean ll is well!.
Surface charge...
Batt probably had a short..
Multi meter... On battery terminals. Turn key of battery voltage falls quickly generally means new battery need
