Fuel pump for 600bhp
Big Mark
A single 485 for mine
Bear in mind youll need the "12v mod" doing for this pump i believe as the 9v wont run it
Easy and safe to do if done correctly using a relay
Something I've always wondered about this is whether or not a standalone ECU sorts this out or if you still have to do it regardless? Can't really find a definite answer! I haven't done it on mine and wondering if I'll need to in the future. I'm running a 255 at the moment and all seems fine
When I fit an ECU I swap the Pump ECU for a 40 amp relay and use either DI or FPR as the ground trigger from the stand alone.
