auto tt oil pressure
Guest Shodaw
hi all,
i need your advice again.
after having the new alarm and immobiliser fitted i decided to do the oil change I've been putting off and whilst at it fit the sandwich plate. having done this i wired in my oil pressure and temp gauges. the car has been running fine though i do get the occasional blue puff from the exhaust on a cold start. i took her out for a run and the oil temp is fine but the pressure started flashing a warning. on idle (around 600rpm) on a warm engine the pressure drops to zero. normal driving (2k-3k rpm) its between 20-30psi. under decent load and a lead foot she hits 90-100psi.
is this normal or do i have yet more issues to go searching for?
