a98pmalcolm Posted September 22, 2016 Share Posted September 22, 2016 Ok so I noticed I have lots of oil residue coming from around the gear box causing drips. I have never done one these before, is it a regular area, how simple is it to sort and is there a gasket involved or sealant? Thanks Paul Quote Link to comment Share on other sites More sharing options...
Rob W Posted September 22, 2016 Share Posted September 22, 2016 Can't you take off the small inspection plate on the side of the box to have a better look? Maybe rear main oil seal? Sometimes the cam cover seals can be leaking and dripping down the back which makes it look like the box. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted September 22, 2016 Share Posted September 22, 2016 I would first check the cam cover seals too. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 22, 2016 Author Share Posted September 22, 2016 (edited) Thanks fellas recently done the cam cover gaskets, will get it onto a ramp soon for a real good look Edited September 22, 2016 by a98pmalcolm (see edit history) Quote Link to comment Share on other sites More sharing options...
Annabella Posted September 22, 2016 Share Posted September 22, 2016 Hope your ram likes tits. Quote Link to comment Share on other sites More sharing options...
MattP Posted September 22, 2016 Share Posted September 22, 2016 Does look like cam covers weaping down the back of the block onto the box. The top of the box is wet and the bottom looks allot drier as if it's coming from above as opposed to leaking from the bottom. No pun intended Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted September 23, 2016 Share Posted September 23, 2016 I would clean all that mess up first as it would be hard to see anything on where its coming from. Get some brake cleaner and wash all that old oil off use a brush to get the really sticky thick parts, go for a drive and then take another look to see what the deal is. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted September 23, 2016 Share Posted September 23, 2016 check prop shaft seal. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 23, 2016 Share Posted September 23, 2016 looks like eng oil to me too. Quote Link to comment Share on other sites More sharing options...
