Indicators blowing fuse, but hazards still work. Any clues?
Kilps
Evening!
So my Supra has been off the road for a couple of months whilst I got round to replacing a leaking coolant pipe. That's all sorted so now of course something else has gone wrong.
My indicators don't work. They were fine before the car had sat for a while.
Hazards work fine on all four corners and side repeaters; side lights work (facelift combined sidelight/indicator units); headlights work; tail lights work.
I checked the fuse (7.5A 'Turn' fuse in drivers footwell) and it was blown. Replaced and still nothing; checked again and the new fuse was blown.
Any ideas what's causing the fuse to blow?
Thats Is what I was going to suggest.
Start the car and check, if it hasn't gone great.
Indicate one side, if it blows, replace and try the other said, if that blows I'm not sure what to suggest.
But if its only 1 side that makes the fuse go take 1 bulb out at a time and replace the fuse each time, hopefully you will then find out which corner or side is dicking about so you know where to start checking all wiring :)
Yeah I'll have a go at that tomorrow.
I had made the assumption that it wouldn't be the light units. Surely if it were, the hazard fuse would blow too?
I was expecting it to be something unique to the indicator circuit... but I don't know what that includes! The switch obviously. Do you know anything else that's on the indicator circuit but not the hazard circuit?
