Guest supragt45 Posted September 19, 2016 Share Posted September 19, 2016 Hi guys,my 1996 non vvti has an obdII port that is round and all over the net there is no info on this,all is about vvti and all... Can the round Mazda pin adapter work with Toyota? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 19, 2016 Share Posted September 19, 2016 Theres no OBD II on that age of cars, its JOBD, you can get the error codes with a paper clip Quote Link to comment Share on other sites More sharing options...
samdale Posted September 19, 2016 Share Posted September 19, 2016 It's all about vvti and torque app via Bluetooth Quote Link to comment Share on other sites More sharing options...
Guest supragt45 Posted October 9, 2016 Share Posted October 9, 2016 Are u sure it wont work?there is an obdII fuse in fuse box Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 9, 2016 Share Posted October 9, 2016 Are u sure it wont work?there is an obdII fuse in fuse box What you trying to find out exactly? As said above a paper clip bent across two of the pins to bridge the terminals will flash the light on the dash to the error code. Takes five mins max, and you will have all the errors stored. Quote Link to comment Share on other sites More sharing options...
Guest supragt45 Posted October 9, 2016 Share Posted October 9, 2016 Need to know if those little obdII pc to port devices will work so I can play with rev,boost and all guages not just clear codes. My car is late 96 and if it is obdII then would also like to know what software to get for it? Quote Link to comment Share on other sites More sharing options...
samdale Posted October 9, 2016 Share Posted October 9, 2016 Is it a vvti? Quote Link to comment Share on other sites More sharing options...
David P Posted October 9, 2016 Share Posted October 9, 2016 Is it a vvti? If you can't read, you can't help. Quote Link to comment Share on other sites More sharing options...
samdale Posted October 9, 2016 Share Posted October 9, 2016 If you can't read, you can't help. Looking back, perhaps I could have made my comment more obvious. A vvti has obd2 and will work. Non vvti is JOBD and won't, as stated in the first reply... Quote Link to comment Share on other sites More sharing options...
Guest supragt45 Posted October 10, 2016 Share Posted October 10, 2016 It is non vvti ... Though different from most other non vvti's ,like an improved spec. It all comes down to the computer box/ecu,guess the standard 2jz GTE non vvti is jobd/obdI. Dont understand why there is a round port with obdII pins and a fuse in the fuse box which has current through it written obdII. Wierd! Quote Link to comment Share on other sites More sharing options...
