1996 FACELIFT NA/TT non-vvti BPU
robby a
SOLD SOLD SOLD SOLD SOLD SOLD Family priorities mean that it is with regret that i,am selling my supra. The car is a j-spec imported by vine place in 2004. I have owned the car since 2011. Current mileage on the clock is 116000 Kms. (72000 mls) The car has only done 4000 since being built. Dyno'd at 406 Bhp. Thousands of pounds worth of receipts. All old mot's. Import paperwork. Won various shows last year. Gathers a crowd everywhere it goes. Hopefully this will go to a forum member. I couldn't bare to put it on eBay [emoji45]
Please see spec below:
BUILT ENGINE (2014)
2jz-gte block, Pressure tested,Decked,Honed and Cleaned by Cleasbys of Durham. Painted gloss black
2jz-gte pistons and rods
New Toyota Piston Rings
New Toyota Oil Pump
New Toyota Engine Gasket Kit
New Toyota Timing Belt + Tenssioner
New Toyota Crankshaft Sensor
New Toyota Timing Sprocket (welded)
New Toyota Water pump
New Toyota Oil Squirters
Titan Crank Pulley
Clevite Bearing + Thrust Washers
ARP Main Bolts
ARP Conrod Bolts
ARP Headstuds + Nuts
2jz-gte Head,Refreshed,Ported, Polished + skimmed.
New Toyota Valve Stem Oil Seals
" " Cam Sensors
" " Breather pipes
" " Coil Packs
" " Thermostat
" " Top Water neck Sensors
Polished Cam covers
Polished Alternator
Polished Pulleys
Polished Top rad pipe with sensor
Polished Top water neck
Polished Bottom water pipe
Polished Turbo pipes
Polished Heat shield
Polished Custom intake pipe + Blitz filter
Polished Throttle body
Polished Hard vac lines (chromed)
Polished Power steering res
Polished Alu rad (whifbitz)
Polished Intercooler and pipes
Polished Twin fan kit
Polished Slam cooling panel
Polished Plinth
Polished Mikalor clamps and Polished Radiator clamps
Polished stainless nuts and bolts
Polished Aircon bracket
Carbon dipped intake plenum
Carbon dipped plug cover
Carbon dipped bonnet struts
Carbon dipped psr cap
Carbon dipped timing covers
Air con delete
Abs delete
TRD OIL CAP
TRD RADIATOR CAP (1.3 BAR)
New silicone joiners,pipes and lines throughout.
K&N oil filter.
Mocal 25 row oil cooler.
Mocal thermostatic sandwich plate with oil pressure and oil temp sensors
SBA Custom oil lines SBA Custom fuel lines sytec fuel filter. Walbro fuel pump. Fuel pulsation dampener removed. Custom braided line installed.
Whifbitz water pipes to matrix .Overflow relocation to chassis leg behind bumper. Washerbottle relocation to boot. Battery relocation to boot (Red top battery) Fusebox relocation under headlight.
Full wire tuck.
UK GLASS HEADLIGHTS with HIDsClear facelift indicators Facelift rear lights with clear indicator mod
EXHAUST 3" Autobahn first decat3" blitz second decat3" blitz nur-spec r catback with 5" slash pipe
GEARBOX&DRIVETRAIN =W58 5 SpeedCompetition stage 4 clutch (6puk)Competition lightened flywheel A101b LSD
WHEELS,BRAKES 18" RAYS VOLK AV3s Continental tyres all round
UK front calipers refurbished with Chris Wilson pistons and seals. Chris Wilson fast rd pads. Stop-tech grooved discs
UK rear calipers, discs and pads are all brand new
HEL Braided teflon custom lines rerouted out of sight
SUSPENSION
BC racing coilovers BA Series
new oem drop links
Suspension geo set up by Revolution
BODYWORK Freshly painted in 199 silver variant. Top Secret front bumper. JDL side skirts blended into sills. Custom Trial rear blended and smoothed UK Bonnet scoop. Rear washer jet delete. Rear wiper delete. Arial delete. debadged. Smoothed engine bay.
Tinted windows.
INTERIOR & ICE Black leather re-trim with grey pipping and toyota badge embroidered into headrests
genuine Alcantara covered dash panels with chrome dash rings
MOMO wheel
MOMO gear knob
MOMO handbrake cover
GREDDY boost controller
GREDDY turbo timer
DEFI GAUGES= Boost,Oil press,Oil temp,Water temp
Heckler led dash conversion in red
Flip front dvd
Sony speakers
Sony type R 12" sub in boot
£15999
Please feel free to ask any questions via pm or in the thread. I'm sure I have missed a lot out. There are loads of pics in the thread but if anyone wants any of a specific area then please ask.
You can also call or txt me on 07463910901
Sold
OK I have sat in silence long enough and can't be sure so i'm just going to ask...
What is NA/TT? Is it a NA converted to twin turbo? I can see its a 2JZ-GTE but I can't see a turbo anywhere on your spec list though.
It was manufactured as an N/a, and had an engine swap to a 2JZ-GTE engine, am I right? And then basic parts upgrade.
