Homer Posted September 16, 2016 Share Posted September 16, 2016 The lights have gone out on these 3 items and controls are not working. Weirdly when I turn the lights on there is some illumination of the heater buttons (I guess they're on a different circuit) I have checked the interior fuses and can't see any of them are blown, but I'm sure I'm missing something obvious. Are there any quick thoughts before I start taking it apart and swapping bits out? TIA! Link to comment Share on other sites More sharing options...
Scooter Posted September 16, 2016 Share Posted September 16, 2016 A possible non fuse cause in this thread, worth a check http://www.mkivsupra.net/vbb/showthread.php?56359-No-Heater-controls-No-Clock-No-Ciggy-Lighter&highlight=lighter+fuse Link to comment Share on other sites More sharing options...
Homer Posted September 16, 2016 Author Share Posted September 16, 2016 Thanks mate, I'll go and check for loose wires! Link to comment Share on other sites More sharing options...
Homer Posted September 16, 2016 Author Share Posted September 16, 2016 Couldn't find any loose wires but reseated all the sockets. I did find that the two wires to the cig lighter had melted slightly and were touching (probably over use of a tyre compressor), so this seems to be the likely cause. I'll re-check the fuses tomorrow. Link to comment Share on other sites More sharing options...
evinX Posted September 16, 2016 Share Posted September 16, 2016 Dimmer switch working? Link to comment Share on other sites More sharing options...
Homer Posted September 16, 2016 Author Share Posted September 16, 2016 Dimmer switch working? That was the "I must be missing something" thing that I couldn't remember!!! I'll have a look at that tomorrow, thanks Kev. Link to comment Share on other sites More sharing options...
Homer Posted September 17, 2016 Author Share Posted September 17, 2016 It was the fuse (caused by a melted cig lighter wire). Numb nuts here was checking the wrong fuse. Link to comment Share on other sites More sharing options...
Sheefa Posted September 18, 2016 Share Posted September 18, 2016 Glad it's sorted mate I fitted my heater dial plates this eve and my heater temp illumination has stopped working, everything else is fine. Going to have to check fuses too tomorrow. Link to comment Share on other sites More sharing options...
Homer Posted September 18, 2016 Author Share Posted September 18, 2016 Check the bulb at the back mate, they're twist-in and can be dislodged when fiddling with the units. If the rest of the unit is lit it won't be a fuse. Each dial has it's own bulb so my money is on that Link to comment Share on other sites More sharing options...
Delboy52 Posted September 19, 2016 Share Posted September 19, 2016 Check the bulbs themselves also. They must be over 20 years old by now if never changed. Found many of mine had all bite the dust on a spare heater unit I've had to install recently. Link to comment Share on other sites More sharing options...
Sheefa Posted September 19, 2016 Share Posted September 19, 2016 Check the bulb at the back mate, they're twist-in and can be dislodged when fiddling with the units. If the rest of the unit is lit it won't be a fuse. Each dial has it's own bulb so my money is on that Will do thanks matey. Link to comment Share on other sites More sharing options...
