Resetting the Air Bag Light
VIL
I need to reset the air bag light and found this on MKIV.COM, has anyone actually tried this? Does it work? Could this cause any damage to the ECU etc.
How to turn off the airbag light:
Problem: Disconnecting the connector behind the upper dash piece where the odometer is located while the ignition key is turned on will result in the airbag light staying on.
Here's how to turn it off :
Go under the hood and open the diagnostic cap located on the passenger-side near the firewall (see photo). Look for AB & TC. Make two plugs with wire to fit into these connectors. With the ignition key turned to the ON position alternate the two wires to the negative terminal of the battery. They need to be done in a consistent rhythm, about one second apart. TC,AB,TC,AB,TC,AB... This needs to be done several times. If you can't get it to work, try adjusting the speed. It is helpful to have someone look at the airbag light while performing this to let you know when the light goes out/blink.
Thanks for that.
Just so I am absolutely clear, my understanding of the above method is to just get two pieces of wire, fix them into the TC and AB points in the diagnosic cap and then touch the negative battery terminal in alternation till it goes out with the ignition on?
Is that right?
  • 2 weeks later...
Thanks for that.
Is that right?
Now I need to do this and I'm still confused. You have a bit of wire leading from the negative terminal on the battery, and you then split the other end of the wire into two and about a second apart put one wire into one socket, then the other wire into the other, and just keep alternating until the light goes out. Is that correct?
Other way round.
Split the wire and put it into the terminal points under the diagnostic cap as mentioned above, then with the bare split wires at the other end keep touching the negaive battery terminal in alternation. Takes a bit to get it right, you really need someone in the car to tell you when the lights gone out.
Use two separate bits of wire. Something like a two core speaker cable would be fine. (thats what I used)
One cable in each terminal (just squidge them in so they stay fixed). Then alternate touching the negative terminal on the battery with exposed cable at the other ends. If your still unsure I think there are photos on MKIV.COM
  • 3 months later...
  • 4 weeks later...
  • 5 months later...
  • 3 weeks later...
  • 1 year later...
Guest DaveWilko
I just did mine. The last owner must have caused it to come on. When I wired in the alarm I found the bulb under the drivers seat and kept it cos didn't know where it came from. When I looked at the panel the bulb was missing so tried the one I found and sure enough the light stayed on. First time I tried the trick it didn't work. I tried again using the second hand on my watch for exactly 30 seconds and the light went out. Happy days! Thanks for the tip.
This all happened cos my lights went out in the right side cluster. Resoldered the connecting socket and all the lights came back. Even the abs one which never worked lol
