supra_jms Posted September 13, 2016 Share Posted September 13, 2016 Bit of history behind this car but will keep it brief. Johnny purchased the car in 1999 and over the years had put many hours time and a lot of money into it. It’s had a lot of quality parts put into it although a little dated by today’s standards, He kept it maintained, doing all the work himself. It has spent some time off the road not being used since 2012. The car was then transferred to Johnny’s Dads house where it has sat until now. The plan was to hopefully sell the car and pass it on to someone who would continue to improve it and enjoy it. SRD offered to help and gave the car a check over and documented the spec. It has a folder full of receipts for parts which show the story of the conversion from stock car to what it is now. Unfortunately SRD did find that the car needs some work to get it up to a usable standard. For that reason it is being offered at a low price with the hope that someone will want to buy it as a project. The price we are asking is £10,000 The spec of the car is below 1993 Toyota supra Hard Top, original 6 speed TT car 125,000 km approx 2JZ-GTE engine, stock block HKS 2835 Twin Turbo Kit with custom water lines HKS 272 Camshafts HKS Cam pulleys (new style) HKS 1000cc Injectors HKS Fuel Rail HKS 4” FMIC Kit HKS SSQV Dump Valve HKS Spark Plugs Aeromotive FPR Uprated Fuel Pump Mocal Engine Oil cooler HKS Midpipe HKS Super Drager Exhaust Sard Analyse ECU Apexi Super AFCII Apexi Turbo Timer SRD Rebuilt Alternator New cam cover seals and washers Metal top rad hose Spal Twin fan Kit on custom brackets V160 6 speed manual RPS MAX Clutch Fidanza Flywheel B03B large case Diff Short Shifter Tein Super Street Suspension AVS Model 5 18" Wheels J Spec brakes with drilled discs Braided Brake lines UK Spec Head lights Sparco Seats Sony Head unit and CD Changer Infinity Auto System Meta alarm and Immobiliser Painted Dash panels Bad points The front turbo has failed so needs a rebuild Compression test results on the engine were a bit low and the engine is a bit noisy so would need a strip down and refresh. 1: 150 2: 162 3: 168 4: 160 5: 160 6: 150 The paint work is not very good and although it looks ok it could do with a respray. The front NS caliper is sticky. Really needs a decent ECU setup Selling as sadly my other supra will not sell so i have no space or funds to take on this car. V5 has just arrived so ready to go Could do with the car being gone this weekend. As you can tell this has been copied from Lees original post as nothing has changed with the car what so ever. [ATTACH=CONFIG]214675[/ATTACH] [ATTACH=CONFIG]214676[/ATTACH] [ATTACH=CONFIG]214677[/ATTACH] [ATTACH=CONFIG]214678[/ATTACH] [ATTACH=CONFIG]214679[/ATTACH] Link to comment Share on other sites More sharing options...
supra_jms Posted September 15, 2016 Author Share Posted September 15, 2016 Sold Link to comment Share on other sites More sharing options...
