NA Air filter and replacement clutch
Guest pedro7256
Guest pedro7256
Hi all!
So pay day is here again so its car parts time!
Im after any recomendations for a replacement aftermarket air filter (been lookign at HKS mushroom types 4inch).
And also want to look into a new clutch as this one is getting a bit high, dont have to be able to run silly power just the standard power for now so any any suggestions?
TIA
Guest pedro7256
Mike: im in Medway rochester area but do travel.
DNK & Pedro: unfortunatly it did not come with the air box only a halfords special filter that has seen seriously better days
I'd try to find a stock airbox for it then, you could try Keron at extreme performance in the traders section, best to call him, or put a wanted advert in the parts section
Guest pedro7256
I may have to look into it! for the min i just need a replacement as this one is extreamly blocked up. The standard box make alot of diffrence? im not really after more power at the moment as will go NA-T when that time comes just something half decent while the misses gets used to it.
