Breaking Track Car.
pedrosixfour
Just a few basics, before we start.
Nothing is sold or ownership implied until money is exchanged.
Please ensure that PayPal charges are covered.
Prices do not include shipping
A reasonable offer is NOT half of the listed price.
Low-ballers will get a reply, but don't blame me if it offends your delicate sensibilities.
Rust-free and damage-free 1995 MKIV SZ-R Manual Shell, some modifications done to go racing.SOLD
Engine & Lubrication
1JZ-GTE, stock except for 440cc injectors. Mileage unknown, but starts instantly and pulls well. ICV could probably do with looking at. £500 SOLD
BC 264 stage 2 camshafts, BNIB £500 SOLD
Works Engineering adjustable cam gears, BNIB £100 SOLD
Setrab 23 row engine oil cooler, c/w oil filter sandwich plate with thermostat and supply/return lines. £150 SOLD
Accusump kit £170 SOLD
Turbocharger & Induction
TRD Panel Air Filter in NA Housing, one clip broken but repaired with pin and strap. £50 SOLD
Custom intake & intercooler pipework to allow use of NA filter housing with a 1JZ or 2JZ TT engine £50
Miami GT SMIC, excellent condition c/w stock ducting £200 SOLD
Fuel, Tuning & ECU
TT Ignitor - £60 SOLD
TT Accelerator Cable - Used -£40 SOLD
A'pexi Neo AFC £80 SOLD
Greddy Boost Controller & solenoid £80 SOLD
Chris Wilson FCD £50 SOLD
HKS FCD £30 SOLD
Aeromotive 340l/h fuel pump £50 SOLD
40L Aluminium fuel cell, c/w internal foam, fuel level sender, 1L swirl pot, two filters, two pumps, braided fuel lines, assortment of pipe ends/fittings and clamps £500 SOLD
Exhaust
Australian-made Y pipe from turbos/ 1st De-cat £200 SOLD
Chris Wilson 2nd decat pipe £80 SOLD
Side exit exhaust from SteveL's track car, c/w mid-pipe £100 SOLD
Drivetrain
Six puk clutch
Lightweight flywheel
R154 5 speed gearbox from JZX90 Chaser, direct fit to Supra
Shortened driveshaft
All of the above available as a kit, along with Marlin Crawler uprated thrust washer, all lines, cylinders, mounts and clutch pedal. £2700 SOLD
Cusco 1.5 way plate LSD with 4.237 FGR c/w Superpro front diff mount inserts £1000 (3 hours on the LSD unit) SOLD
Suspension, Wheels, Tyres & Brakes
Titan Motorsport Front & rear anti-roll bars £250 SOLD
Power steering cooler, c/w lines £50 SOLD
TT Power steering fluid reservoir, including supply pipe. - £50 SOLD
OFF CAR Height adjustable Chris Wilson custom valved "fast road" Bilstein dampers & matched springs. £600 SOLD
Carbing solid front strut brace with BMC stopper £200 SOLD
Front upper wishbones, complete with Superpro polyurethane inner bushes. £30 each SOLD
Superpro extra caster and camber kit for front lower wishbones - Brand new bushes - £120 SOLD
Superpro rear subframe bush kit - Brand new - REDUCED TO 120
Superpro Supra steering rack bush kit - Brand new - £30 SOLD
Front subframe, alloy section - £50 STEEL SECTION SOLD
Rear subframe, has second diff mount recently fitted - £100 SOLD
DBA 4000 series brake discs as new £200 SOLD
UK spec brake calipers, c/w braided lines £550 SOLD
17" Volk Challenge F-Zero alloy wheels 10" +44 Rears, 9" +38 Fronts £250 SOLD
17" Volk Challenge F-Zero alloy wheels 9" +44 Rears, 8" +36 Fronts £200 SOLD
17" Work Emotion Cr Kai alloy wheels 9" +42, pair only £200 SOLD
18" Ultralite GT2 alloy wheels, 9.5" +35 Rears, 8.5" +30 Fronts, c/w Federal 595RS/R track rubber 255/35 & 285/30 one front tyre a bit shook, rest are good £600
18" WedsSport SA67-R alloy wheels, 10" +35, two pairs (ie 4 wheels same spec) almost perfect, small scuff on one wheel lip £850 SOLD
Four Michelin Pilot Sport Cup Tyres, new, never even fitted, 285-30-18. Tyres are a couple of years old at this, stage but always stored in a warm dry loft. Price drop to £500
BNIB Tyresure TPMS kit £160
H&R 15mm hubcentric spacers with longer studs £60 SOLD
Interior
Manual pre-facelift dash clocks, modified to work with a 1JZ engine (resistor bridged) but easily reverted to work with a 2JZ £60 SOLD
Sparco EVO3 fixed bucket seats & side mounts (x2) £400 SOLD
Sparco 3" 4 point harnesses (x2) £100 SOLD
Sparco suede steering wheel on extended boss £60 SOLD
HKS engine oil temp gauge
HKS engine oil pressure gauge
HKS water temperature gauge
HKS fuel pressure gauge
HKS Turbo Boost Pressure Gauge
The above gauges are complete with working senders & should really sell as a kit. - £250 SOLD
Exterior
MVP polyurethane front lip £100 SOLD
BNIB Heated windscreen £250 SOLD
BNIB 5 Polycarbonate window kit from P4P, c/w edge stiffeners, slider kits & scoops, quarter windows and rear window with three pre-drilled hooded vents £750 SOLD
I'd have some presentable pieces of stock parts and trim. The underpinnings of the car and the chassis itself are as clean as a two or three year old car, no rust, and I've yet to come a cross a seized bolt, nut or adjuster of any sort. Some body panels and parts are in good condition and could be reused.
I'd need to sort out what else is available and update the thread accordingly.
Most parts already fitted have only done a matter of hours/couple of hundred miles over the last number of years, some even less and were fitted brand new last year.
Thanks,
Damien.
  • Replies 180
Hi Damien
I'm interested in the DBA 4000 series brake discs. Can you get me a photo or a link please? Assume straight swap for UK discs?
Also the Carbing strut brace and stopper. Photos awaited please.
Cash waiting.
Cheers
Greg
Hi Greg.
The DBA discs are indeed stock replacements.
Taken on the day of fitting
There is obviously some surface rust present now but absolutely no lip has formed due to the few times I've been out on track and all discs are free of cracks or warping as they were always allowed to cool over a lap prior to being stationary.
The front brace. It is designed for the NA engine but will fit a TT with no alterations or problems. A brace for a TT will not fit the NA however
Suspension arms
Steering wheel
Sparco Harnesses
Pics of these please :).
/QUOTE]
You'll have to wait for the pics of the suspension arms mate, they're still on the car and I didn't bother taking pics during the rebush.
That job was torture enough without stopping every five minutes to pick up a camera.:)
I'll see if I have any shots saved of the wheel, failing that I'll post a link to the same and get some snaps of it possibly tomorrow, definitely Monday, same with the harnesses.
Someone this side of the pond did express genuine interest in the wheel along with the fuel cell and even popped over to take a few measurements from the tank to check his boot for space.
I'm interested in the power steering cooler; do you have any pics?
Not of the cooler unobscured by the front bumper mate, no. I only took a few snaps during the duct building phase. There is certainly a thread knocking about somewhere but is probably of little use to you
I'll get you some within a day or two
Pics and condition of the MVP polyurethane front lip please pal.
You could have a look at a few snaps in my garage mate, there'd be several more in the track car thread in chat.
It's unpainted, still with its ears, bolted to the bumper as the original lip would be and a small bead of sealer at the joint to keep grit out.
It has never had an impact and I don't recall seeing anything in the line of cosmetic damage either lately
This topic is now closed to further replies.
