Alex_GT Posted September 3, 2016 Share Posted September 3, 2016 I have been trying to find a replacement LSD if in the event I need one, does this one fit a Japanese spec tiptronic auto? I tried to do a search for the model of the differential but it didn't return any results so not sure if it has already been discussed. Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted September 6, 2016 Author Share Posted September 6, 2016 Anyone? I've tried the search function on the forum but it doesn't produce any results (apart from this thread now). Quote Link to comment Share on other sites More sharing options...
Nic Posted September 7, 2016 Share Posted September 7, 2016 (edited) http://www.kaazusa.com/lsd_toyota.html Their website lists the DAT3020 as fitting the 96.06~onwards JZA80 Supra. All J-spec Supras post this date (NA, TT, Auto, Tip and 6spd) were fitted with the smaller A diff. The axle code on your VIN plate should start with an A if it does and it has the original diff fitted then according to the website it should fit. See here for an explanation of the axle codes http://mkiv.supras.org.nz/specs.htm Only the pre 96.06 TT 6spd Supras were factory fitted with the larger B diff. Edited September 7, 2016 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted September 9, 2016 Author Share Posted September 9, 2016 Yes the VIN plate says it has the A02A diiferential, but apparently that is not what is fitted at the moment. Thank you for the explanation, at least I know it will fit. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 10, 2016 Share Posted September 10, 2016 Left is the larger B diff fitted to the pre 96.06 J-spec TT 6spd, right is the smaller A diff fitted to all other J-spec models. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted September 20, 2016 Share Posted September 20, 2016 (edited) We supply KAAZ LSD'd and have 2x standard DAT3020's and 2x Super-Q DAT3020-WPC's in stock. Notes on our system says if the car is a TT 6-Speed or using the diff from a TT 6-Speed model, it will not fit.... Edited September 20, 2016 by Richie_k83 (see edit history) Quote Link to comment Share on other sites More sharing options...
