Syvecs - First time fitting
Big Mark
Going single and probably going down the Syvecs route with the Syvecs S6Plus Supra ECU Plug & Play Kit
As it's plug and play does that mean I literally can plug it in and get a map on it (download a base map if possible or get the whole car mapped) and it's good to go?
Or do I need to change/add the various sensors below first?
NTK Wide band
3.5 bar map sensor
10 Bar Pressure sensor
Boost solenoid Kit
Bosch Knock Sensor
No, its not exactly true plug and play. you need to ask Syvecs if you can run all the stock sensors bar perhaps the MAP sensor, which may need changing to a wider range one depending on your goals for boost level. I agree with np89 though, and most people don't use anything like the full capability of a Syvecs, so a cheaper ecu may be a lot more cost effective *IF* you can find a competent mapper that's available and not on a different continent. I have seen good results with Link ecus. But *NOTHING* betas MOTEC for levels of support and the number of competent mappers here in the UK.
