fastcar Posted August 31, 2016 Share Posted August 31, 2016 Looking at getting a new set of wheels for the supra but need a little help to see if the rear wheel sizes will fit under stock arches. The rear arches have been rolled so there is a little more room to play with! Wheels I'm looking at are the Volk TE37SL 18" 10" wide with offsets of either 20 or 40 on the rear. Not bothered with fronts as I know they will fit just the rears. Also need to fit over UK brakes! Thanks in advance Quote Link to comment Share on other sites More sharing options...
mattdavies Posted August 31, 2016 Share Posted August 31, 2016 If you are happy to run a 265 / 255 tyre then you can run ET20 on a 10" rim and an arch roll Quote Link to comment Share on other sites More sharing options...
fastcar Posted August 31, 2016 Author Share Posted August 31, 2016 If you are happy to run a 265 / 255 tyre then you can run ET20 on a 10" rim and an arch roll Would the wheel be sticking out of the arch on ET20 with a 10" wide! I had this on my old CE28s, they were 10.5 ET18? Quote Link to comment Share on other sites More sharing options...
David P Posted August 31, 2016 Share Posted August 31, 2016 (edited) Here's a pic of a 255 on a 10". https://www.google.co.uk/search?q=255+tyre+on+10%22+wheel&rlz=1C1CHBF_en-GBGB703GB703&espv=2&biw=1024&bih=476&source=lnms&tbm=isch&sa=X&ved=0ahUKEwih-NC9-evOAhVCJcAKHQiFABEQ_AUIBigB#imgrc=yTNcMdwvlFbceM%3A First kerb will toast your posh new wheels. Edited August 31, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
fastcar Posted August 31, 2016 Author Share Posted August 31, 2016 Here's a pic of a 255 on a 10". https://www.google.co.uk/search?q=255+tyre+on+10%22+wheel&rlz=1C1CHBF_en-GBGB703GB703&espv=2&biw=1024&bih=476&source=lnms&tbm=isch&sa=X&ved=0ahUKEwih-NC9-evOAhVCJcAKHQiFABEQ_AUIBigB#imgrc=yTNcMdwvlFbceM%3A First kerb will toast your posh new wheels. That's why I hate stretched tyres! Constantly refurbing my old CE28's Quote Link to comment Share on other sites More sharing options...
baldy Posted August 31, 2016 Share Posted August 31, 2016 id go et40 and run 295/30 tyres, im running 295/30 on 10 et35 with rolled arches and no issuses Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted August 31, 2016 Share Posted August 31, 2016 Mine are 19x10.5 rear with a 295/35 and a small arch roll and there's no rubbing. As above I'd go for a bigger ET and a bigger tyre Quote Link to comment Share on other sites More sharing options...
jot_ie Posted August 31, 2016 Share Posted August 31, 2016 315 rear tyre on 18x11.5 et49 wheels, rear arch roll Put some of the specs in the thread into http://www.willtheyfit.com/. That will tell you how much further out or in they will be Quote Link to comment Share on other sites More sharing options...
Nic Posted August 31, 2016 Share Posted August 31, 2016 Looking at getting a new set of wheels for the supra but need a little help to see if the rear wheel sizes will fit under stock arches. The rear arches have been rolled so there is a little more room to play with! Wheels I'm looking at are the Volk TE37SL 18" 10" wide with offsets of either 20 or 40 on the rear. Not bothered with fronts as I know they will fit just the rears. Also need to fit over UK brakes! The rear wheels in the pic of my car below are 18x10 +32 with 285/35R18 tyres fitted, the arches are rolled slightly to stop the outside of the tyre catching (more pics in my garage HERE.) In comparison to mine 18x10 +40 wheels would sit 8mm further inwards and should easily clear the wheel arches without rubbing. In comparison to mine 18x10 +20 wheels would extend outwards an extra 12mm, you would need to have the arches pulled and rolled to prevent the tyre catching. Quote Link to comment Share on other sites More sharing options...
Axl Posted August 31, 2016 Share Posted August 31, 2016 You want round ones mate:jester: Quote Link to comment Share on other sites More sharing options...
fastcar Posted August 31, 2016 Author Share Posted August 31, 2016 You want round ones mate:jester: Again.......I'm going to beat you with a large stick:p Quote Link to comment Share on other sites More sharing options...
fastcar Posted August 31, 2016 Author Share Posted August 31, 2016 The rear wheels in the pic of my car below are 18x10 +32 with 285/35R18 tyres fitted, the arches are rolled slightly to stop the outside of the tyre catching (more pics in my garage HERE.) In comparison to mine 18x10 +40 wheels would sit 8mm further inwards and should easily clear the wheel arches without rubbing. In comparison to mine 18x10 +20 wheels would extend outwards an extra 12mm, you would need to have the arches pulled and rolled to prevent the tyre catching. http://www.mkivsupra.net/vbb/vbpgimage.php?do=full&p=744&d=1134501037 What sizes do you have up front nic? Quote Link to comment Share on other sites More sharing options...
Axl Posted September 1, 2016 Share Posted September 1, 2016 Again.......I'm going to beat you with a large stick:p Quote Link to comment Share on other sites More sharing options...
Nic Posted September 1, 2016 Share Posted September 1, 2016 What sizes do you have up front nic? 18x9 +32 245/40R18 Quote Link to comment Share on other sites More sharing options...
