andz222 Posted August 30, 2016 Share Posted August 30, 2016 Just bought this rad cap brand new and it started leaking already Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 30, 2016 Share Posted August 30, 2016 Good, because 1.3bar is crazy pressure, stock id only 0.9 I think. Also is it a fake HKS? Quote Link to comment Share on other sites More sharing options...
andz222 Posted August 30, 2016 Author Share Posted August 30, 2016 im not on a stock radiator Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 1, 2016 Share Posted September 1, 2016 Your heater matrix may not like a high coolant pressure should the temperature make it rise higher than stock. You can't buy new genuine matrices any more either. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 1, 2016 Share Posted September 1, 2016 Arn't all after market rad caps 1.3 bar? All after market rads use 1.3bar caps. Even a TRD one is 1.3bar Sounds like a crap Rad Cap mate. My Mishimoto one leaked so I bought a blitz one from Paul and its been perfect Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 1, 2016 Share Posted September 1, 2016 Just check the HKS one hasn't got any debris under the little sping loaded one way valve if you want to continue using it. The valve allows vacuum in the rad to pull fluid from the "overflow" reservoir. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted September 1, 2016 Share Posted September 1, 2016 OEM standard opening pressure is 0.95 to 1.25, minimum opening pressure of 0.8 HKS do a 1.1 bar cap for the R33, thats what I use Quote Link to comment Share on other sites More sharing options...
andz222 Posted September 1, 2016 Author Share Posted September 1, 2016 ok will check - - - Updated - - - Just check the HKS one hasn't got any debris under the little sping loaded one way valve if you want to continue using it. The valve allows vacuum in the rad to pull fluid from the "overflow" reservoir. ok Quote Link to comment Share on other sites More sharing options...
andz222 Posted September 1, 2016 Author Share Posted September 1, 2016 Arn't all after market rad caps 1.3 bar? All after market rads use 1.3bar caps. Even a TRD one is 1.3bar Sounds like a crap Rad Cap mate. My Mishimoto one leaked so I bought a blitz one from Paul and its been perfect gonna try another cap i think my filler neck is damaged if so another radiator Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 1, 2016 Share Posted September 1, 2016 What rad is it? Quote Link to comment Share on other sites More sharing options...
andz222 Posted September 2, 2016 Author Share Posted September 2, 2016 its a golpher radiator Quote Link to comment Share on other sites More sharing options...
