2JZ-GE Front & Rear crank oil seals
evinX
Eventually id like to do this as mine weep a little. Nothing major but would like to tackle it
Anyone used these? prices seem very reasonable over Toyota would like to hear if they are any good
http://www.ebay.co.uk/itm/New-Front-Rear-Crank-Crankshaft-Oil-Seal-Set-For-JZA80-Supra-Mk4-2JZ-GE-/112107596487?hash=item1a1a222ac7:g:B~gAAOSwgZ1XvagT
cheers, Kev
Not something i should bother to worry about doing then?
You can change the front crank seal with the front of the car jacked up, but the front side of the engine has to come off more or less.
Rear crank requires gearbox to come off.
Both do-able with engine in car, but nice and easy with engine out
Ahhh ok cheers for that, im not at that stage where i need to bring the engine and box out, ill give it another 10 years :D
