wile e coyote Posted September 8, 2016 Share Posted September 8, 2016 Glad you all sorted HD Link to comment Share on other sites More sharing options...
Fearless Posted September 8, 2016 Author Share Posted September 8, 2016 Thanks for all the support, it's been a challenge but really enjoyed doing it. Link to comment Share on other sites More sharing options...
Littler Posted September 8, 2016 Share Posted September 8, 2016 That is fantastic! Great work! Link to comment Share on other sites More sharing options...
DodgyRog Posted September 11, 2016 Share Posted September 11, 2016 That's awesome Steve, really impressive bud and you get Brownie points from Shirley, what a bonus lol Link to comment Share on other sites More sharing options...
Fearless Posted September 12, 2016 Author Share Posted September 12, 2016 That's awesome Steve, really impressive bud and you get Brownie points from Shirley, what a bonus lol Thank you what she doesn't know is this is just the prep work for a bigger supercharger Link to comment Share on other sites More sharing options...
Delboy52 Posted October 3, 2016 Share Posted October 3, 2016 Hi Steve I know it's a bit off topic but which UZ engine are you using, 1 or 3UZ? Does your Syvecs ECU do a good job of controlling the VVT system? Great work with the supercharger btw Link to comment Share on other sites More sharing options...
Fearless Posted October 4, 2016 Author Share Posted October 4, 2016 It's the 1UZ engine. The bottom end is the 1st gen with the stronger con rods and the heads are from the 2nd gen with the VVT but although the Syvecs is perfectly capable of controlling the VVT for simplicity I have fixed the VVT mechanism so the cam timing is the same as the 1st gen non VVT heads however they are a slightly higher lift and a more aggressive profile. Link to comment Share on other sites More sharing options...
Delboy52 Posted October 4, 2016 Share Posted October 4, 2016 Thanks Steve, that's great to know. Link to comment Share on other sites More sharing options...
EdMorris Posted October 5, 2016 Share Posted October 5, 2016 Excellent piece of home engineering. I love it, well done. Link to comment Share on other sites More sharing options...
Fearless Posted October 9, 2016 Author Share Posted October 9, 2016 (edited) OK so there are always going to be a few teething problems with anything new so I was expecting something to need tweaking. So it was no surprise that the belt from the clutch to the supercharger started to slip at max rpm and of course once it started to slip the slippage got worse very quickly. So 3 belts later I came up with this It's a belt tensioner from a mini with a custom mounting bracket however despite many attempts to get this to run true and 5 belts later I have given up on that idea. The arm is just too flexible and being that close to the driven pulley there is no margin for error and it keeps chucking the belt off the pulley. So I thought all it really needs is a bit more wrap around the pulley rather than more tension on the belt so I made a simple idler pulley (this is just a prototype made from some scrap so excuse the roughness of it) This is what it looks like and it works brilliantly! Only one problem now, it may be because I have been putting a lot of tension on the belt or it may just be normal ware and tare (this was a used charger when I brought it) but the oil seal on the input shaft has started leaking now. Edited October 9, 2016 by Fearless (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted October 9, 2016 Share Posted October 9, 2016 The simplest solutions are often the best Link to comment Share on other sites More sharing options...
Pudsey Posted October 9, 2016 Share Posted October 9, 2016 Great to see you keeping this alive. Which forced induction method do you think is best for the 1uz-fe, supercharged or turbocharged? Link to comment Share on other sites More sharing options...
Fearless Posted October 9, 2016 Author Share Posted October 9, 2016 I always had issues with heat when this was turbocharged both single and twin. They have to go in front of the engine so you end up with a mass of red hot manifold pipes adding heat and blocking airflow through the radiator. Was fine driving normally but didn't take many mins. pushing it before coolant was at 110c and oil was at 130c This never even gets close to overheating now Link to comment Share on other sites More sharing options...
