Help needed to test ecu
cainhead
Hello,
Before I take the last resort of sending my AEM back to the USA to be tested. Would anyone be willing to help me out. Basically I need test my AEM V2 on someones car. I need to check that it powers up each time the key is turned to the on position. I can probably do it without even starting the car as I can plug it in to my laptop and check its connecting to the software. Im based in the SW London are but willing to travel if anyone can help. Many beers to anyone that can help.
If you cant no worries.
Cheers
Andrew
Yeah checked everything, all the pins that are supposed to get power are doing so. I also tested my stock ECU and thats working everytime.
Have you checked to see if pin 1 on ECU is getting a ignition feed will save you swapping ECU also do you have the engine management Light illuminated when ignition is ON as its the same fuse circuit
