brassbones Posted August 22, 2016 Share Posted August 22, 2016 The top row of buttons for the climate control don't light up but the bottom row does. I took the dash panel off and replaced the upper bulb to no effect. Anyone know what might be going on there? Quote Link to comment Share on other sites More sharing options...
rider Posted August 22, 2016 Share Posted August 22, 2016 My back lights on the controller, sometimes they work and sometimes they don't. Sometimes some work and some don't. Sometimes all work and sometimes none work. So your problem may well not be bulb related but dry joints. Test the old bulbs to see if they are actually blown as you may find they are OK. Quote Link to comment Share on other sites More sharing options...
brassbones Posted August 23, 2016 Author Share Posted August 23, 2016 Is there a solution for dry joints other than swapping out the control module? Quote Link to comment Share on other sites More sharing options...
jim Posted August 23, 2016 Share Posted August 23, 2016 People generally solder them bud apologies for stating the obvious and asking the question, but you haven't got the dash dimmer switch set to dark? Quote Link to comment Share on other sites More sharing options...
brassbones Posted August 23, 2016 Author Share Posted August 23, 2016 Nah, its on max. The lower row is fine. On the upper row the green leds above the buttons work but the button backlights dont. Quote Link to comment Share on other sites More sharing options...
