Guest Ss property Posted August 20, 2016 Share Posted August 20, 2016 Hi the 3 lights you get on the right hand side dosent seem to be working it may be the bulb but does anyone know how to check and replace the bulbs Thanks Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted August 20, 2016 Share Posted August 20, 2016 Hi mate, Do you mean the oil lights? If so take the upper plastics off there's about 5 or 6 screws which will remove it and you will see if that part of the loom is connected! Have a look at that first. Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted August 20, 2016 Share Posted August 20, 2016 The white clip here mate. Quote Link to comment Share on other sites More sharing options...
Ric Posted August 20, 2016 Share Posted August 20, 2016 it will be the solder issue. The solder joints crack very very common just try a search, you just need to re-solder it, 5 minute job once it's apart Just resolder all the main connections again and 99% sure it will start working again. Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 20, 2016 Share Posted August 20, 2016 try tapping the front mine are like that small tap and on they come Quote Link to comment Share on other sites More sharing options...
Ric Posted August 20, 2016 Share Posted August 20, 2016 will be the solder issues peter, tapping it makes the connection again, just take it out and solder it! Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 20, 2016 Share Posted August 20, 2016 ok mate on the to do list Quote Link to comment Share on other sites More sharing options...
Andrew K Posted August 20, 2016 Share Posted August 20, 2016 Mine was like this when I first bought the car, done as said above and resoldered the connections on the back and it's been working perfectly now which is 7 years later. Quote Link to comment Share on other sites More sharing options...
brassbones Posted August 20, 2016 Share Posted August 20, 2016 On the subject of dash bulbs ... the top row of buttons for the climate control dont light up but the bottom row does. I took the dash panel off and replaced the upper bulb to no effect. Anyone know what might be going on there? Quote Link to comment Share on other sites More sharing options...
