U.K. Bonnet scoop
Mac Srt
everything is still avail from Toyota afaik, except mounting brackets....however I have a guy now who has replicated the oem brackets so we now have the full kit avail....
If they are the same ones made by the guy in Auz they are a perfect fit. I didn't think the scoop grille/mesh insert was still available though.
I was looking at fitting them properly. Do they make much difference other than the looks ?
They were installed on European supra's to cope with the increased speed limit and high speed cruising of the autobahns. It provided cooling to back of the engine around cylinder 6 via a snorkel attached to the underside of the bonnet. I doubt you would see much benefit in this country to be honest.
