New ecu; what sensors to use
Noz
My ECU of choice is AEM Infinity.
Basic outlay;
Boost control / solenoid
Wideband to ECU
Map sensor
So, what other inputs should I consider. As these were outside my current quote.
Other recommendations include;
Fuel Pressure
Fuel Mix (Ethanol)
Oil Pressure
Oil Temperature
Air Intake
Water Temp
Exhaust Gas Temp
What other sensors are recommended for someone wanting the very best from their technology? Aiming for 600hp, but will want nitrous at some point.
Edited by Noz (see edit history)
I was thinking Knock Sensor too. I'll update the list!
I'd like ethanol, a better option to nitrous.
I've been advised sensors are not necessary although these would be the main ones to go for if i did: Oil pressure, fuel pressure and wideband sensors
Better hope you don't get a drop in oil pressure or fuel pump failure then mate. Personally I'd agree with you and say those two things are major benefits from monitoring with a new ECU like this.
I'd rather pay an extra couple of hundred pounds for sensors overboard, because I can't afford all these upgrades then have my engine fail. If the ECU can monitor it, then I want to include it to save money in the long run.
You don't have a fuel pressure sensor, not enough inputs.
I have been battling the ABS, a sensor was dead, or dying, I finally found the good used ones I have and it's fitted now.
This loom adaptor is anything but plug n play by the way....! Romain will have to take some cables and pins out to add the new ones, as i don't know what inputs he wants to use for what.
You mean if I stack up the inputs I won't be able to use fuel pressure?
Yeah I've the custom loom resolved, it was included in my quote.
Frank, I didn't really get any recommendations for what sensors. However, if my pump fails and he says I shouldn't usually need one, he wouldn't be liable for my engine and it would still lye with me to pay for the repair.
I agree 100%, and its something thats going to be incorporated on my build once i get something better than the w58 on there. Id rather have that peace of mind knowing that everything is being monitored and add some additional sensors on there. Which Version did you go for on the infinity?
Sorry, that was aimed at Frank Bullit! He doesn't have enough inputs with the Tiptronic and the sequential turbos to run a fuel pressure sensor, but the mixture will go weak and they can probably map it to kill the engine on the O2 sensor output figures instead.
