Thermal Sleeve
Jellybean
Hey
I have some Braid dash 10 Oil lines running from the oil Filter (Located in the Carbon Canister location) to the sandwich plate ; The lines do touch against some grounding cables ,in particular the earth cable running to the battery in the boot
Is it good practice to put a thermal sleeve on the oil lines ?
thanks
Ah, makes sense now. Can you re-route cables away from hot pipes? or use clips to separate the 2?
I did as best I can but its tight down the side of the intake , think I will just thermal sleeve a few items and put a small piece of rad piping around the braided line to keep it up off the cable and minimise thermal transfer
Insulation on the cables is a few mm thick but rather have them heat protected for piece of mind
Not quite sure what your worried about, if its just the touching/abrasion of the power cable, just use some rubber/foam sleeve, the braided oil pipes will not pick up heat due to the fact that the oil is moving, and its already at 90-100c anyway, and if your seeing under bonnet temps of more than the oil temp you need to address this anyway.
