TBDevelopments Posted August 13, 2016 Share Posted August 13, 2016 need part numbers for the following connectors, for the life pf me i cant find them in the epc. Heated seat switch connector Uk fog light switch connector Uk headlight washer connector Trac switch connector Cruise control connector, inside the steering wheel Thanks guys Tim TBDevelopments Quote Link to comment Share on other sites More sharing options...
Lee P Posted August 14, 2016 Share Posted August 14, 2016 The plugs have a 5 digit number on, it's quite small. If you don't have the original plugs to look then hopfully someone who has can help out with that If you ring Steve Manley with this number he can look up the part numbers and order them up 01865 291333 Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 14, 2016 Share Posted August 14, 2016 Be prepared for a horrible bill. The connector for the heated seat switch cost circa £30 Quote Link to comment Share on other sites More sharing options...
Nic Posted August 14, 2016 Share Posted August 14, 2016 Get the 5 digit number off the plug then check here for the full part number.toyota plugs.pdf Quote Link to comment Share on other sites More sharing options...
and1c Posted August 14, 2016 Share Posted August 14, 2016 Nice info, cheers. Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 14, 2016 Author Share Posted August 14, 2016 great, that pdf really helps. Now i just need someone to look at there uk loom for those 5 digit numbers lol Tim TB Developments Quote Link to comment Share on other sites More sharing options...
