Tsia Posted August 13, 2016 Share Posted August 13, 2016 Afternoon all, I'm trying to pop my injectors out to get them tested & cleaned as they seem to be sticking. They're SARDs, but fitted on the standard rail. How on earth do you get the throttle body off?! I've located the two bolts underneath it, but they're nigh-on impossible to get to, let alone undo to remove the TB from the manifold. So, I have two questions! 1. Is it possible to somehow remove the injectors/fuel rail without taking the intake manifold off 2. If not, has anybody got a rough guide on removing the TB and intake manifold? Ta Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 14, 2016 Share Posted August 14, 2016 There are FOUR bolts holding the throttle body on. You also need to remove 2 water heating hoses from it. All are easy to reach with a three eighths drive socket set Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted August 14, 2016 Share Posted August 14, 2016 Yep, as Chris says. A 3/8 socket set, with a long extension for the bottom bolts. They're 12mm heads. Only takes 5 mins Quote Link to comment Share on other sites More sharing options...
Tsia Posted August 15, 2016 Author Share Posted August 15, 2016 Yep, as Chris says. A 3/8 socket set, with a long extension for the bottom bolts. They're 12mm heads. Only takes 5 mins /QUOTE] I've got hands like a chinese factory worker and still couldn't get them down towards those bolts at the bottom - this'll end well Cheers Quote Link to comment Share on other sites More sharing options...
