jonny mac Posted August 11, 2016 Share Posted August 11, 2016 £800 ALL IN, IGNORE THE £1000 IN THE TITLE. Item:- EMU Ecu Master Stand Alone + Parts Condition/Mileage:- Brand new Price:- £800, I paid more than that for the unit + all accessories/loom, should still have the invoice in my paypal for proof Postage:- Free within UK Item will be packaged in/with:-a courier from interparcel or parcel2go Or Collection From:- Scotland, address isn't relevant until money changes hands. Bought this brand new from MAC Motorsport, it still has warranty as it's a matter of months old, I bought basically everything to install this onto a 2jz. You'll get basically everything needed: ECU Unit, Built in 3 bar map sensor so no need to buy one Pre Terminated Universal Harness + Plugs + Colour Chart/Pinout Guide Bosch knock sensor EMU air intake temp sensor (very important) EMU Oil pressure sensor EMU Oil temp sensor also whatever else I have for this, I also have a set of fiat coil pack connectors as marcin said to use fiat punto new style turbo coil packs as they are good for any hp level I also paid extra for the Bluetooth sensor to use with a tablet for a digital live display dash! you can create your own display to provide a life feed of everything that the ecu is reading works fine with vvti and non vvti engines, this can also support some spec taken from the company's description: Technical details 6 fuel injector outputs (5A) 6 AUX outputs (5A) 6 ignition outputs -passive or active coils software selectable (7A) 4 stepper motor outputs - bipolar/unipolar (1A) 2 EGT direct inputs 2 knock sensor inputs Inbuilt wide band lambda controller LSU 4.2 Inbuilt map sensor 400kPa Inbuilt baro sensor 4 digital inputs VR/HALL – software selectable 3 dedicated analogue inputs (TPS, CLT, IAT) 4 additional analogue inputs (0-5V) compliance with ISO 7637 support 1-12 cylinders max rpm 16000 injection time resolution 16us ignition advance resolution 0,5 deg knock sensing 1-20 kHz Speed Density, Alpha-N algorithm table VE 16x16, resolution 0,1% VE ignition table 16x16, resolution 0,5 deg AFR Target table 16x16m, resolution 0,1 AFR Injector voltage compensation coil dwell calibration user calibrated IAT, CLT PID idle control strategy boost control, nitro injection control; Aux outputs for fuel pumps, rad fan .. motorsport strategies launch control, gear dependent shift light, flat shift ( gear change cut) logging over 100 parameters possibility of check engine lamp USB communication no additional interface needed user friendly software with free firmware upgrade pm on here is fine or my number is 07939 550861, call me for a chat if anyone is serious about this Link to comment Share on other sites More sharing options...
badboyz Posted August 11, 2016 Share Posted August 11, 2016 I'll give you £500 for it Link to comment Share on other sites More sharing options...
122fraser Posted August 12, 2016 Share Posted August 12, 2016 ouch^ Link to comment Share on other sites More sharing options...
sebas Posted August 12, 2016 Share Posted August 12, 2016 sorry for hijacking your thread, but can anyone tell me if there is anyone in UK who can fit and map Ecumaster Emu into Supra? Link to comment Share on other sites More sharing options...
jonny mac Posted August 12, 2016 Author Share Posted August 12, 2016 For anyone doubting the asking price, here's what I paid months ago. It's all brand new. Link to comment Share on other sites More sharing options...
Hena Posted August 12, 2016 Share Posted August 12, 2016 You can get these cheap from Poland but all menus are in polish language. English versions are more expensive.. Link to comment Share on other sites More sharing options...
jonny mac Posted August 12, 2016 Author Share Posted August 12, 2016 This is the English version. That's why it was a higher price. Link to comment Share on other sites More sharing options...
Nodalmighty Posted August 12, 2016 Share Posted August 12, 2016 JamSport are the main distributor for these. RRR Engineering was my supplier but I found them a bit useless when it came to responding to questions. I found Sam @ JamSport very helpful though. Link to comment Share on other sites More sharing options...
jonny mac Posted August 15, 2016 Author Share Posted August 15, 2016 Sold Link to comment Share on other sites More sharing options...
