EMU Ecu Master Stand Alone System, brand new £1000
jonny mac
£800 ALL IN, IGNORE THE £1000 IN THE TITLE.
Item:- EMU Ecu Master Stand Alone + Parts
Condition/Mileage:- Brand new
Price:- £800, I paid more than that for the unit + all accessories/loom, should still have the invoice in my paypal for proof
Postage:- Free within UK
Item will be packaged in/with:-a courier from interparcel or parcel2go
Or
Collection From:- Scotland, address isn't relevant until money changes hands.
Bought this brand new from MAC Motorsport, it still has warranty as it's a matter of months old, I bought basically everything to install this onto a 2jz.
You'll get basically everything needed:
ECU Unit, Built in 3 bar map sensor so no need to buy one
Pre Terminated Universal Harness + Plugs + Colour Chart/Pinout Guide
Bosch knock sensor
EMU air intake temp sensor (very important)
EMU Oil pressure sensor
EMU Oil temp sensor
also whatever else I have for this, I also have a set of fiat coil pack connectors as marcin said to use fiat punto new style turbo coil packs as they are good for any hp level
I also paid extra for the Bluetooth sensor to use with a tablet for a digital live display dash! you can create your own display to provide a life feed of everything that the ecu is reading
works fine with vvti and non vvti engines, this can also support
some spec taken from the company's description:
Technical details
6 fuel injector outputs (5A)
6 AUX outputs (5A)
6 ignition outputs -passive or active coils software selectable (7A)
4 stepper motor outputs - bipolar/unipolar (1A)
2 EGT direct inputs
2 knock sensor inputs
Inbuilt wide band lambda controller LSU 4.2
Inbuilt map sensor 400kPa
Inbuilt baro sensor
4 digital inputs VR/HALL – software selectable
3 dedicated analogue inputs (TPS, CLT, IAT)
4 additional analogue inputs (0-5V)
compliance with ISO 7637
support 1-12 cylinders
max rpm 16000
injection time resolution 16us
ignition advance resolution 0,5 deg
knock sensing 1-20 kHz
Speed Density, Alpha-N algorithm
table VE 16x16, resolution 0,1% VE
ignition table 16x16, resolution 0,5 deg
AFR Target table 16x16m, resolution 0,1 AFR
Injector voltage compensation
coil dwell calibration
user calibrated IAT, CLT
PID idle control strategy
boost control,
nitro injection control;
Aux outputs for fuel pumps, rad fan ..
motorsport strategies launch control, gear dependent shift light, flat shift ( gear change cut)
logging over 100 parameters
possibility of check engine lamp
USB communication no additional interface needed
user friendly software with free firmware upgrade
pm on here is fine or my number is 07939 550861, call me for a chat if anyone is serious about this
