Fuel pulsation dampener removal adapter
berg
Im buying all the parts to make my new fuel lines up and i now have everything other than the line from the filter to the rail (fuel pulsation dampener removal if you like)
Im wondering if anyone knows the thread pitch etc of the adapter i need for the fuel filter?
My lines are all AN-6 im just not sure about the thread on the filter
Cheers
45 degree Double Swivel fitting (To use on the Fuel Filter) and a 90 degree Double swivel fitting (To use on the Rail) ,
Outlet at the fuel pump hanger and the inlet for the fuel filter are 14x1.5 inverted flare , Outlet is 12 x 1.25 for fuel filter to rail,
I have a top feed rail , that is a 12 x 1.25 too, should be the same on the OEM rail as I had the OEM Fuel pulsation pipe connected
Dont forget some copper washers ;)
I would not bother unless you need to run over 600 hp as the noise without the pulsation damper is a tad annoying , you can hear the fuel gurgling
Edited by Jellybean (see edit history)
