Fuel issue questions? ?
HELLBOY666
Hi there been having a few issues with my n/a auto over fueling I've purchased a big single auto to use but really thinking of selling it and keeping my original n/a seems as it was my first supra 😉 but anyway AA recovered me the other week outside tesco main doors of all places lol he went through dizzy, leads, injectors and all connections and the only thing he could do was to disconnect fuel pump get me to start so it would clear the flood then he could connect bk up before it would run out of fuel but every time he tried it was cutting out like it was instantly flooding so after 5-6 attempts to clear injectors and connect pump bk up he gave up said let it run out of fuel with pump disconnected??? but car never stopped it was still running the whole time he towed me home he couldn't understand why and he reckons the fuel pump ecu could be faulty.....? it now runs ruff and idles at 1800-2500k and if i put throttle down it tries cutting out still so really stumped ? what do you guys think it would be much appreciated so I can fix it and sell my single 😆 thanks in advance [emoji106]
Ah so the overfueling is on the na, not the NA-T. There is no fuel ecu on an na. check your ignition timing, and whilst car idles unplug each injector individually, if you don't hear a difference when you unplug then you will have an issue with the fuel side. try and identify what cylinder issue is on, and if you can make the problem go to another cylinder or not
Edited by Mike2JZ (see edit history)
Yeah sorry I'm driving a 2jz gte single auto at the min but it just don't feel like my car lol it wasn't my first supra so would like to just use the na and thanks ill try the injectors individually but I know the ones in middle are gonna be a pain lol
There is a fuel ecu on an na. It's in the same place as a tt. Left side of boot behind the trim. I doubt if that's the problem tho. My guess would be fuel pressure regulator. The part in the last pic
/QUOTE]
Ah yes you are correct, didn't believe it till I checked the diagrams. Located in bottom right of image if you want to see it's location
And I also had a play around with the dizzy I just pulled plug out which then engine wanted to die as should but gently put plug bk in not all the way wiggled it and got it to idle at 1300rpm not 2200 ????? should I look into dizzy side as I've also noticed a hole in my HT leads which has appeared from no where...
