TT Paul Posted August 8, 2016 Share Posted August 8, 2016 After these bolts/studs if anyone has some please pm me with price Inc UK postage. Link to comment Share on other sites More sharing options...
simon197911 Posted August 8, 2016 Share Posted August 8, 2016 After these bolts/studs if anyone has some please pm me with price Inc UK postage. I've got both sets, not new though. let me know if any good Link to comment Share on other sites More sharing options...
Richie_k83 Posted August 10, 2016 Share Posted August 10, 2016 After these bolts/studs if anyone has some please pm me with price Inc UK postage. I have both sets available from stock if needed, let me know. Link to comment Share on other sites More sharing options...
TT Paul Posted August 11, 2016 Author Share Posted August 11, 2016 Anyone Link to comment Share on other sites More sharing options...
RobUK Posted August 11, 2016 Share Posted August 11, 2016 SRD sell these too http://srdtuning.com/shop/index.php?route=product/product&path=60&product_id=73 Link to comment Share on other sites More sharing options...
Burna Posted August 12, 2016 Share Posted August 12, 2016 Surely you can't use a second hand used set?! They are designed to stretch when tightened to the specified torque figure, so once used they are no good after, or am I wrong here? Link to comment Share on other sites More sharing options...
RobUK Posted August 12, 2016 Share Posted August 12, 2016 Surely you can't use a second hand used set?! They are designed to stretch when tightened to the specified torque figure, so once used they are no good after, or am I wrong here? You are correct Link to comment Share on other sites More sharing options...
markssupra Posted August 12, 2016 Share Posted August 12, 2016 Arp can be reused I'm sure. From Arp site. Are ARP bolts and studs re-usable? Yes. As long as the fasteners have been installed and torqued correctly, and show no visible signs of damage, they can be re-used. If they show any signs of thread galling or corrosion, they should be replaced. In the case of rod bolts, if any of them have taken a permanent set and have stretched by .001” or longer, you should replace them immediately. See page 29 in the catalog for more detailed information on this critical measurement. Surely you can't use a second hand used set?! They are designed to stretch when tightened to the specified torque figure, so once used they are no good after, or am I wrong here? Link to comment Share on other sites More sharing options...
Burna Posted August 12, 2016 Share Posted August 12, 2016 You are correct Ooo Ooo do I win that jacket now?!? Link to comment Share on other sites More sharing options...
Burna Posted August 12, 2016 Share Posted August 12, 2016 Arp can be reused I'm sure. From Arp site. Are ARP bolts and studs re-usable? Yes. As long as the fasteners have been installed and torqued correctly, and show no visible signs of damage, they can be re-used. If they show any signs of thread galling or corrosion, they should be replaced. In the case of rod bolts, if any of them have taken a permanent set and have stretched by .001” or longer, you should replace them immediately. See page 29 in the catalog for more detailed information on this critical measurement. Ah that makes sense. So if they've been torqued correctly, and not over torqued and therefore not stretched, then yes it's ok to reuse them. But anything over 10 thou of stretch and they are no good? I'd rather not cut corners and I would buy new myself. Link to comment Share on other sites More sharing options...
RobUK Posted August 12, 2016 Share Posted August 12, 2016 Considering you won't know that state the used bolts would be in, I wouldn't buy used... If you Lee was taking my engine apart having built it then I'd say that's fine:) Link to comment Share on other sites More sharing options...
markssupra Posted August 12, 2016 Share Posted August 12, 2016 1 thou of stretch, not 10. 10 thou is 0.010" Ah that makes sense. So if they've been torqued correctly, and not over torqued and therefore not stretched, then yes it's ok to reuse them. But anything over 10 thou of stretch and they are no good? I'd rather not cut corners and I would buy new myself. Link to comment Share on other sites More sharing options...
Burna Posted August 12, 2016 Share Posted August 12, 2016 Considering you won't know that state the used bolts would be in, I wouldn't buy used... If you Lee was taking my engine apart having built it then I'd say that's fine:) Well if you're having an engine built then the cost of a new set of ARP's is nothing in the grande scheme of things! You can't do something like that on the cheap, and if you did you'd never sell the car for good money after anyway, word get's around. - - - Updated - - - 1 thou of stretch, not 10. 10 thou is 0.010" You're right, my mistake I just didn't imagine it to be that little! So fuck all stretch is all it needs to make them non reusable, I'd buy new. Link to comment Share on other sites More sharing options...
Richie_k83 Posted August 12, 2016 Share Posted August 12, 2016 Surely you can't use a second hand used set?! They are designed to stretch when tightened to the specified torque figure, so once used they are no good after, or am I wrong here? They can be re used. However, you must use a stretch gauge to ensure they are still safe to use. Link to comment Share on other sites More sharing options...
bignum Posted August 12, 2016 Share Posted August 12, 2016 I always thought arps were designed to not stretch so you can reuse them many times.(unless overtorqued makes sense) Link to comment Share on other sites More sharing options...
