Help needed - Cant get flat tyre off
hamzahkhan
Dear Fellow Members -
I am stuck in a rather unfortunate situation. Luckily the car is in the garage but it has a flat tyre. I cant seem to get the wheel off because the wheel lock is a different gauge to the wheel brace. The wheel lock I believe is hexagonal and 19mm.
So rather than spend a fortune calling the usual suspects out to help get a wheel off I thought I'd try my luck and see if there were any members in London that would be able to help me out or offer some advice?!
Thanks!
Absolutely - The key is hexagon 19 mm with 5 raised points that fit into the smooth wheel lock nut. However the key is of a different gauge to my brace. Hence the request to see if someone had a 19mm brace/socket that I could momentarily borrow.
Can't see the point in locking wheel nuts any more. When was the last time anyone heard of a set of wheels being stolen? The lack of thefts of wheels these days could either be because everyone already has alloy wheels or everyone assumes that every set has locking wheel nuts which if you really wanted to steal are a simple steal by banging an undersized socket on or using a pin socket. I haven't bothered with the things for years and any car that came with them had standard wheel nuts put on to replace the locking nut.
