side repeaters removal
ronttuk
When I changed mine for clear lenses they came out really easily by pushing hard left and lifting out right. Then they are a simple sprung clip snap back. If you are swapping the lenses rather than just changing the bulbs you'll likely want to reuse the gasket as the aftermarket ones are really flimsy compare to the original fit. So don't go prodding screwdrivers in to lift the light units out of the panel or you may well end up damaging the gasket.
