Weeping NEW AN Fitting -- help
Jellybean
  • 5 Hose Greddy Oil cooler and filter relocation
  • TRD oil Filter
  • BMRS Fittings and Lines
I have installed new AN double swivel Dash 10 fittings , One of the fittings has a tiny weep (indicated by ARROW below) , a 1mm worth of oil after a run ( 50 KM) on the fitting, they are Brown and Miller Solutions (As used by Nascar and F1 teams) good quality ;
I relocated the oil filter to the engine bay and have setup as per diagram below , the oil filter has a none return valve , if it was incorrectly connected the flow of oil would not enter the filter due to the valve, not too sure is this causing a back up of oil to seep out
what is the best way to check as I hate replying on diagrams , anybody and experience with a weeping fitting to suggest what to check?
How hot should the filter get after a run?
Diagram
Arrow indicates where it weeps
Edited by Jellybean (see edit history)
