Adding eSATA ports to a PC.
Digsy
I would like to add at least one eSATA port to my home PC.
Is an eSATA port simply an internal SATA connection rouetd to the back of the PC - i.e. you just need an adapter cable linked to a backplate as per THIS.
...or is eSATA something completely different and therefore you need a proper eSATA controller, like THIS.
I have plenty of spare SATA connections on my motherboard, so I don't want to buy a controller card if a simple adapter will do.
Thanks! :)
*EDIT* I know that if I want the drive to be hot-swappable (which I do) then the simple adapter option will only work if my mobo supports hot swapping, so maybe that answers my own question: I will only need the full controller card if my mobo won't support the hot swap feature.
My external drive supports USB and eSATA and has its own power supply, so its only the data side I am concerned with.
I checked by mobo manual last night and it says the on-board SATA ports support hot plugging, so I should be OK with just the cheapo adaptor cable / plate.
