nos or rltc?
supra dan
Thorin, are you sure?
I would have thought that as long as all injectors were cu, N02 would pass through safely?
Alternatively, if that is the case, you could alway use the N02 shot further down the track when the car has traction.
I reckon the drag radials would be the most cost-efficient mod, for drag use only. The RLTC and N02 enhance the road performance as well as the track.
But you have NOS AND extra Fuel being added with a NOS install. Most NOS installs supply their own fuel though an additional injector in the intake pipe. The trac control would cut all the injectors but the NOS system will still pump fuel in.
Bang.
Which is why I said all injectors have to be cut, the RLTC has capacity to do this. So N02 and RLTC are fine as long as the RLTC controls the extra fuel?
Obviously allowing just the N02 fuel in would make a very lean mix, and a very big bang ;)
I don't know if the RLTC has the ability to control the additional injector, does it? Even so it would need to be able to acurately cut it at the same time as the normal injectors and I'm not sure I'd trust it.
I don't think it is designed to do that. Alternatively you could get the box from RaceLogic that makes the TC control the spark instead of the fuel (for cars without MPFI), that way you would not ignite the mixture but it would dump loads of fuel and NOS out the back, which I'm sure would get ignited by something.:flame Dev
Hmmm, interesting idea. OK I want RLTC AND NOS ;)
No in the normal way it doesn't, but it may be possible.
The problem is that most NOS and fuel jets are nothing more than a small tube. Their flow is mechanically controlled via solonoids. The injectors have no electrical signal whatsoever. The only way around it would be to stop the solonoids seeing a power signal.
Theres absolutley no way I'd want to see NOS and fuel being injected on a car whilst RLTC is activated. Could be devastating. A customer of ours fiddled with an install we done and manged to activate it whilst the engine wasn't running. He had a NOS ignition inside the inlet manifold and promptly blew every single boost and vacuum pipes to pieces. He was v. lucky he didn't blow the manifold apart or bend the throttle plate like a banana.
You may be able, if you set the NOS trigger point to be at a high boost level, to get away with it. Most turbo cars, whilst running an activated RLTC will not make over 1 bar. If your NOS was set at say 1.2 you might be alright.
But you might not.
Look into it carefully, and plan it out. Just don't let some divvy tuner just slap it all on there.
Regards,
Nathan
TDI PLC
