charlton Posted July 29, 2016 Share Posted July 29, 2016 My old supra never failed for no airbag Link to comment Share on other sites More sharing options...
tintinmt Posted July 29, 2016 Share Posted July 29, 2016 Steering wheel replacement - if you go that route, isn't difficult and is well documented on here. There will need to be an electrical connection made for the airbag to operate so you would need to make sure the wiring is in place before buying an airbag wheel. Another issue to possibly be aware of is that some parcel couriers will not carry airbag units. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 29, 2016 Share Posted July 29, 2016 Take it to a different tester Link to comment Share on other sites More sharing options...
Noz Posted July 30, 2016 Share Posted July 30, 2016 Go somewhere else. Sounds loke they are over reacting. Link to comment Share on other sites More sharing options...
navtrd Posted July 30, 2016 Share Posted July 30, 2016 My old rz supra auto never had a airbag never a issue with m.o.t. Link to comment Share on other sites More sharing options...
supra900bhp Posted July 30, 2016 Share Posted July 30, 2016 I think they got the hope of getting a older car off the road or trying to make you pay through the nose for something not needed. I have had mine mot'ed for the last 10 odd years at 4 or 5 different places and it has always past with a aftermarket wheel and NO airbag. I would take it somewhere else and provide pics if needed to show it never come from factory with it fitted. Good luck buddy Link to comment Share on other sites More sharing options...
Pete Posted July 30, 2016 Share Posted July 30, 2016 And I think all GZ and some RZ pre facelift models came with the same 4 spoke wheel as the UK cars. Not sure if NA's came with the 4 spoke wheel, but I suspect it was probably an option like the RZ. My '94 NA SZ had a three spoke wheel and an airbag. Link to comment Share on other sites More sharing options...
Pete Posted July 30, 2016 Share Posted July 30, 2016 From what I've just been reading around it looks like the rules changed around 2013/14 to say if an airbag was "fitted as original equipment" then it should be there. Quite how they'll be able to prove that all MkIV imported Supras should have an airbag I don't know. I'd ask him, "How can I check if my imported spec vehicle for Japanese domestic market originally came with an airbag?" Link to comment Share on other sites More sharing options...
Annabella Posted July 30, 2016 Share Posted July 30, 2016 From what I've just been reading around it looks like the rules changed around 2013/14 to say if an airbag was "fitted as original equipment" then it should be there. Quite how they'll be able to prove that all MkIV imported Supras should have an airbag I don't know. I'd ask him, "How can I check if my imported spec vehicle for Japanese domestic market originally came with an airbag?" I'd say the onus is on the tester to check whether it had one or not. It would then fall back to just the light for error codes, and if not then a pass. Link to comment Share on other sites More sharing options...
Al Massey Posted July 30, 2016 Share Posted July 30, 2016 Section 5 of the MOT manual from the government covers airbags. It does not state it must have an airbag, it states if it is obviously missing. https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/518634/mot-inspection-manual-for-class-3-4-5-and-7-vehicles.pdf Link to comment Share on other sites More sharing options...
Annabella Posted July 30, 2016 Share Posted July 30, 2016 Method of Inspection 1. As far as practicable, check that all airbags fitted as original equipment are present and not obviously defective. Reason for rejection. 1. An airbag obviously missing or defective. As above reads it is correct to fail if they can prove that the car had an airbag when manufactured. Link to comment Share on other sites More sharing options...
Al Massey Posted July 30, 2016 Share Posted July 30, 2016 Method of Inspection 1. As far as practicable, check that all airbags fitted as original equipment are present and not obviously defective. Reason for rejection. 1. An airbag obviously missing or defective. As above reads it is correct to fail if they can prove that the car had an airbag when manufactured. Not really as its not obvious, unless the light is on and there's a big hole where it should be. And it would be hard to prove if it came as standard or not. Link to comment Share on other sites More sharing options...
Annabella Posted July 30, 2016 Share Posted July 30, 2016 That is pretty much what I said. Link to comment Share on other sites More sharing options...
