Scratch and Swirl Mark remover..
MattP
Whole car needs a good polish to be honest Peter the marks are minor swirls and hologram marks I always make a mess with the machine polisher.
I was going to use some of these white and black hand waffle pads from G3 but need to know what polishes etc and order I should use them.
Been reading about detailing and all the products today. I'm generally a little cynical about it all but it does interest me.
Is the black hole stuff really that good?
I was reading about rotary polishers and the complexity of it all scares me!
Black hole is lovely to work with but it's a filler product and only masks the scratches etc for so long it's a temporary fix for a show or a quick go over but i really need to sort these swirls etc properly now.
It depends on how bad the paint work is but try the Meguiars 205, I normally use it with a DA polisher and it works perfectly.
If the Meguiars 205 don't seem to remove much then the 105 is the next step. Of course once that's done, a good glaze and wax will finish the job.
trial and error , but unless you have a few option product wise its going to be tough , if its just a few light marks and holos a decent finishing product will get them out without any serious stage work . where abouts are you see if there is a good detailer near .
a one stage finishing wont cost a lot , saves you getting stuff and doing it yourself
What would you use personally for lights swirl and hologram removal Peter its worth getting the stuff as I spend ages yearly on the car anyway its not a one off thing.
3m polishes are best IMO, the secret to machine polishing is often doing it a 2nd time with a finishing polish, usually people use a polish which is too harsh then just leave holograms everywhere.
3m Ultrafina is one of the best I've used at this, they do 3 polishes for various stages inc the pads etc.
I'd go with this, 3M Fast Cut on a DA, use with plenty of water if your first time. Then 3M Ultrafina to get rid of the holograms.
Don't need expensive pads or machines - I started out detailing with a £25 DA and £3 pads with 3M compounds working on £50-100k cars everyday.
If you plan on doing the whole car save yourself a lot of time and pain, get yourself one of these: http://www.halfords.com/motoring/car-cleaning/polishers-steam-cleaners/meguiars-mt320-dual-action-polisher-pad-kit
Or with the compound/polish bottles: http://www.halfords.com/motoring/car-cleaning/polishers-steam-cleaners/meguiars-mt320-dual-action-polisher-ultimate-kit
Very easy for a beginner to use due to dual action head, variable speed, decent build quality.
You'll be surprised how many times you whip it out to polish out the odd scratch or car park mark on various cars in the future. I've helped a few mates out with mine now.
Only thing is that the cutting compound isn't really hard enough for deep scratches, I'd like to find something more abrasive for difficult corrections.
If you're a beginner please don't buy the meguires one, paying for a brand
http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/cat_81.html
This is almost half the price and is very very good, i use one along side my rotary. various polish kits avail.
That's what I've got, the Pro Plus version, albeit not used it yet. I will be cracking it out in next few weekends. Great price for the kit ;)
I have been using a rotary for ages on the boat but on car paint I have no idea what speed I should be using for cutting and finishing
I have 6 speed settings as you can see below
Hook and loop adapter plate
Orange waffle cutting pads with black waffle finishing pads
What speed should I be cutting (Orange pad) at with this rotary?
And what speed with the (Black Pad) finishing pad?
Using Megs 205 and 105 ultra cut and finish.
Theres never a set speed to use.
Just start slow to work the polish around the panel then speed up to make your passes
go perhaps half speed and see how quickly the polish breaks down and how the finish is, once you've got a feel for it you could speed up more to reduce the time taken. Just don't press too hard with a rotary or hold in the same place for a long time or you'll burn it.
