raddys Posted July 28, 2016 Share Posted July 28, 2016 Ive tried searching but i cant find any concrete answers, basically im looking at a set of wheels that are.. 18-9.5j et10.. will these fit all round? Many thanks Link to comment Share on other sites More sharing options...
Big Mark Posted July 28, 2016 Share Posted July 28, 2016 http://www.supraforums.com/forum/showthread.php?558091-Wheel-Tire-Size-Offset-Thread-Search-here! Link to comment Share on other sites More sharing options...
jim Posted July 28, 2016 Share Posted July 28, 2016 They'd be a fairly aggressive fitment on the rears (but should fit with arch work or stretching the tyres), fronts I don't think will work - my set up was fairly flush on the front and when I compare it to what you're suggesting, the calculator says they'll stick out about 3cm further. Link to comment Share on other sites More sharing options...
James Posted July 28, 2016 Share Posted July 28, 2016 I'm 9.5 et21 up front and it's very aggressive already. You'll need to run a 225 to avoid hitting your arch. Possibly need to go very low too to get that bit of naturally induced negative camber too. I'm 11.5 et37 on the rear so 9.5 et10 would poke 1.6mm more. I have a flared rear though so get away with it. I'd be rolling your rears at least, if not flaring/cutting. I'll get pictures of mine for you when I'm in from work. Link to comment Share on other sites More sharing options...
raddys Posted July 28, 2016 Author Share Posted July 28, 2016 Nice, cheers for the help lads Link to comment Share on other sites More sharing options...
