Parts from going single
cainhead
Have a load of stuff from going single. The car was a UK spec manual non vvti. The only exception is the charcoal canister which was from an n/a. Price are open to offers but could do with some help on pricing with a couple of bits. If you think its way under, or over please say. All prices plus postage, or if around the SW London and up to 50 miles away could work out drop off on larger items for the cost of fuel. Thanks for looking.
Chris Wilson FCD - Only car for only a few months, removed as running AEM ECU. - £35 sold
OEM Radiator - Well used but was not leaking when removed, few bent fins and could do with a clean - Offers
Charcoal Canister - £10
All turbo VSV's - £15 each
UK airbox with HKS panel filter - £50
MAF sensor - No idea so offers welcome
1st and 2nd Decat in one. Also has port for wideband AFR sensor along with port for downstream 02 sensor. Bolts straight onto manifold. No holes dents - £120
Turbo heat shield - £10
UK twin turbos. Look in good condition with fins intact. They seem like there is no play but i have never seen another set in person to gauge this so very welcome to check them out first. Were working fine when removed. All oil pipes etc would come with them and would add the turbo pipe work for an extra £30 - £300 on their own. - Prov Sold
Turbo pipework with whifbits silicone turbo link pipes in good condition. Offers around £40 if not sold with turbos.
Boost pipework from turbo side in white - £10
UK ECU £75
Chrome relay cover £10
Fuel rail with 550cc injectors and resistor pack - £150
Random items in last few pictures. Think they are fuel related but make an offer for anything you see.
  • 2 weeks later...
  • 2 weeks later...
  • 5 months later...
