On the hunt for..
Mike2JZ
Steering cowl
NA radiator with auto oil cooler. Oem or aftermarket, (looking for one that allows for normal size PS hoses to be attached so i can ditch ugly stock cooler)
NA fan shroud (no broken clips etc)
Battery Tray + Holder
Stock airbox lower and upper intake plastics
Rear drop links
powersteering pump rebuild kit
Front wheel arches
I have lower intake plastic if you need it. I still have my oem auto radiator minus the oil cooler nipples as needed them for my aluminium radiator and it is a bit bogging inside so would need a good flush with a cleaner.
