Elliot Posted September 17, 2005 Share Posted September 17, 2005 Just gone outside to warm the car. Turned the alarm on, then off, and then turned the key in the ignition. I did this twice. The first two times it made a funny sound (one loud click) like the battery was dead, then cut power instantly, even to the interior lights etc. The third time, the engine started first time no problems. What could it be? Straightaway I thought dead battery, but can't imagine why it would start a third time like that with no problems? Could it possibly be a problem with the starter motor? I'm not sure if I'm imagining it or not, but the alarm key fob seemed to be stuck in, so maybe it's that. Going to pop out for a drive now & see how it goes, anyone had similar problems? Link to comment Share on other sites More sharing options...
magicmatty Posted September 17, 2005 Share Posted September 17, 2005 Similar thread, this or last week I think...mine runs a couple of alarm LED's and if left for a week or more, it clicks for a couple of time, then bursts into life ok.? ? ? Never does it again, unless I dont start it for a while again (week or so) Link to comment Share on other sites More sharing options...
Pixelfill Posted September 17, 2005 Share Posted September 17, 2005 Mine does the same if it's been left for a week or so. Pleased to hear that this is normal, I thought I was going to have to get a new battery. Is there anything I can do to minimise the drain. Mike Link to comment Share on other sites More sharing options...
dangerous brain Posted September 17, 2005 Share Posted September 17, 2005 I know it sounds stupid but is it a dodgy solenoid lol. I'm sure that on start up all other power to the car is stopped because the start circuit needs all available power. You don't normally see this though as mostly the car kicks over straight away. Link to comment Share on other sites More sharing options...
Elliot Posted September 17, 2005 Author Share Posted September 17, 2005 I drove it last night for about an hour, after not having driven it for around a week, but have left it longer before and that hasn't happened... I just went to go out for a quick drive, but there are some very funny noises occuring! One of the belts sounds very loose, neat the front of the engine bay, and there is a loud ticking nearer the back of the engine bay. Inside, there sounds like there's a moth flying around the dash, just above the right air-con fan (by keys) I can't see a thing as it's pitch black, so will have to have a more detailed check tomorrow. Gutted. The clock's reset as well... Link to comment Share on other sites More sharing options...
Elliot Posted September 17, 2005 Author Share Posted September 17, 2005 I know it sounds stupid but is it a dodgy solenoid lol. I'm sure that on start up all other power to the car is stopped because the start circuit needs all available power. You don't normally see this though as mostly the car kicks over straight away. Not sure, I've just started it again no problem first time. I've never had any problems starting the car first time with just the key (whereas some other cars I've had to give it some pedal as well!) A dodgy solenoid would be a relief considering the other noises it's making! Incidentally, where should I be checking if that was the case? Link to comment Share on other sites More sharing options...
dangerous brain Posted September 17, 2005 Share Posted September 17, 2005 I dunno but sticky solenoids sound bloody awful. Really nasty loud clicky rasping noises. Link to comment Share on other sites More sharing options...
TrickTT Posted September 18, 2005 Share Posted September 18, 2005 sounds like the solenoid to me - had the same problem last week. Hope it is anyway, its a cheap easy fix Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2005 Share Posted September 18, 2005 A dodgy solenoid won't cause the car to lose power to the interior light or reset the close. I'd guess it's loose battery terminals. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 18, 2005 Share Posted September 18, 2005 or reset the close. Reset the what now? Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2005 Share Posted September 18, 2005 Reset the what now? Doh! Reset the clock... Link to comment Share on other sites More sharing options...
Terminator Posted September 18, 2005 Share Posted September 18, 2005 A dodgy solenoid won't cause the car to lose power to the interior light or reset the close. I'd guess it's loose battery terminals. Take the clamps off the battery, clean them and the posts with emery paper and apply copper grease and tighten. Link to comment Share on other sites More sharing options...
TrickTT Posted September 18, 2005 Share Posted September 18, 2005 A dodgy solenoid won't cause the car to lose power to the interior light or reset the close. I'd guess it's loose battery terminals.correct me if i'm wrong, but doesn't the "starter" position on the key kill power to non essentials, clock/stereo/lights etc. Link to comment Share on other sites More sharing options...
dangerous brain Posted September 18, 2005 Share Posted September 18, 2005 Thats what I thought too Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 18, 2005 Share Posted September 18, 2005 It kills power to non-essentials connected to the 'Acc'essory line yes, but not the interior light and clock. I think Toyota considered that re-setting the clock after every start-up could become quite tiresome Link to comment Share on other sites More sharing options...
