Fog Light PCBs
heckler
  • 3 weeks later...
  • 2 weeks later...
Hello;
I've tried to contact heckler with one PM but no answer yet, so i try here:
i just want to understand how Fog light PCBs work :
if i install 2 Fog light PCBs,
- without pushing on the fog light button, the 4 brake light work as usually ( light on when i hit the brake pedal )
- with side light on and if i push the fog light button, there will be 2 brake light who will work as brake light, and two other "brake light" who will still be on ..
is it correct ?
if yes I'm interested, and if heckler can answer my PM ?
Cheers
Bastien
Hello;
is it correct ?
Cheers
Bastien
Yup - spot on 😀
Hello;
is it correct ?
Cheers
Bastien
And replied...
  • 2 weeks later...
  • 1 year later...
  • 5 months later...
Is there still a fitting guide somewhere for these?! Currently going about putting my car back on the road and need to install them for the MOT.
Fit the PCB as per the photo.
The Red wire is from the fog light switch.
If you fit two of the PCB's connect a wire between them then connect the one on the drivers side to the fog light switch.
[ATTACH=CONFIG]228936[/ATTACH]
