Twin turbo Posted July 14, 2016 Share Posted July 14, 2016 Hi got this annoing noise from under my car(jdm tt automatic 93 mod)like rattle mostly from rear i think when driving at Even very Low speed on normal roads.sounds like something lose like damper top mounts. Had my mecanic take a look but he could not find anything wrong with suspension. Got a new tanabe exhaust and he told me it might cause it,but tried wiggle hard but nothing there and the sound was present before i replaced the exhaust. Tourqed those damper top mounts lifted both wheels looking for any play,no movement there either.changed those rubber(hatch) Sparewheel and Jack firmly at place,Looked at seatbelt and put down rear seat still rattle[ANGRY] Very little play from both rear wheel bearing but mecanic says its within normal? Very low milage car and have not found anything that looks worn.Dampers are oem bilstein and never changed i think,very firm very little movement when i press down. Can anything come loose inside make that sounds. Anything else typical for this model to look for? All suggestions appreciated. Quote Link to comment Share on other sites More sharing options...
inazone Posted July 14, 2016 Share Posted July 14, 2016 Have you checked the oem exhaust shields under the car. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted July 14, 2016 Share Posted July 14, 2016 drop links Quote Link to comment Share on other sites More sharing options...
