ellis Posted July 12, 2016 Share Posted July 12, 2016 There's varying replies on the forum for this but can someone clarify the facelift clock hole size for fitting a boost gauge please. Some say 52mm, others 60mm - all I know is it's called a hole I can't measure. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted July 12, 2016 Share Posted July 12, 2016 (edited) Where the facelift clock is, I fitted a AEM air to fuel ratio gauge there and the gauges are 52mm. I surpose you could fit a 60mm but you probably need a bit of sanding. Air vents you could fit a 60mm Edited July 12, 2016 by Dim Sum (see edit history) Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted July 12, 2016 Share Posted July 12, 2016 Pre facelift is 52mm I was always under the impression the facelift is slightly bigger. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted July 12, 2016 Share Posted July 12, 2016 all I know is it's called a hole I can't measure. Is that what you tell Mrs G? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted July 12, 2016 Share Posted July 12, 2016 The facelift is definitely larger, quite a bit so. Unfortunately I didn't take a measurement, but I can say without a doubt that a gauge that fits one won't fit the other. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted July 12, 2016 Share Posted July 12, 2016 Just measured the random spare facelift one I have, 63mm diameter. Quote Link to comment Share on other sites More sharing options...
ellis Posted July 12, 2016 Author Share Posted July 12, 2016 Just measured the random spare facelift one I have, 63mm diameter. Cheers mate - definitive answer Quote Link to comment Share on other sites More sharing options...
ellis Posted July 12, 2016 Author Share Posted July 12, 2016 Is that what you tell Mrs G? It's like throwing a cocktail sausage inside a cathedral mate. Quote Link to comment Share on other sites More sharing options...
