coza Posted July 11, 2016 Share Posted July 11, 2016 Hi Issues with my power steering , I had a leak and didnt spot it until the steering got really hard to turn I put new fluid and the colour of that turn brown after a few miles and the pump doesn't seem to work any ideas ? Quote Link to comment Share on other sites More sharing options...
and1c Posted July 11, 2016 Share Posted July 11, 2016 Your pumps goosed?! Whiffbitz sells new ones if you visit their site. Quote Link to comment Share on other sites More sharing options...
and1c Posted July 11, 2016 Share Posted July 11, 2016 Probs worth taking the accessory belt of and seeing how freely the pump spins. See if there is any shaft wobble etc Mine was making a rattling noise when the engine was up to temperature, but the PS was still working. Quote Link to comment Share on other sites More sharing options...
coza Posted July 11, 2016 Author Share Posted July 11, 2016 Yeah il check the website out but it's noisey and not working so gonna have to be changed Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted July 11, 2016 Share Posted July 11, 2016 (edited) I had a similar issue.. I topped up using VW stuff and my steering went super stiff. Its the type of fluid you have uses, also mixing old with new, you need to use dexron 3. You wont need much, its with doing a full bleed before replacing. I did this and it sorted the problem. I made a thread some were one min.. - - - Updated - - - Here you are http://www.mkivsupra.net/vbb/archive/index.php/t-327752.html And this is what you will need, only 2L is plenty http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/car-tranmission-oils/automatic-transmission-fluids/?522776012&0&cc5_869 Edited July 11, 2016 by a98pmalcolm (see edit history) Quote Link to comment Share on other sites More sharing options...
coza Posted July 12, 2016 Author Share Posted July 12, 2016 where did you buy dexron 3 from ? , il give that a go first before i buy a new pump Quote Link to comment Share on other sites More sharing options...
Homer Posted July 12, 2016 Share Posted July 12, 2016 where did you buy dexron 3 from ? , il give that a go first before i buy a new pump It's available everywhere, even Halfords stock it. Do follow the guide Malcolm posted if the fluid isn't nice and clean and the system still isn't working correctly, it solved a similar issue with my PAS system. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted July 12, 2016 Share Posted July 12, 2016 I put a link on my post for euro car parts buddy Quote Link to comment Share on other sites More sharing options...
coza Posted July 12, 2016 Author Share Posted July 12, 2016 I put a link on my post for euro car parts buddy Nice one , Quote Link to comment Share on other sites More sharing options...
