drifter Posted July 6, 2016 Share Posted July 6, 2016 Hi looking for advice My #2turbo has died.on my uk spec manual Am I better to go single r Get the turbos rebuilt . I have been looking at pro torque single Kit on supra store R a secondhand hks Td04z kit car is stock Link to comment Share on other sites More sharing options...
JasonR24 Posted July 6, 2016 Share Posted July 6, 2016 I just had this happen to be. Got my turbos rebuilt as it cost 1200 for those plus fitting. Whereas going single turbo properly is around £20k Depends on what you can afford and what you're end goals are and if you really need the power but it's a lot more money. Whatever you choose. Good luck! Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 6, 2016 Share Posted July 6, 2016 Depends what your goals are for the car. I must admit a UK spec manual is a rare car and will be a collectors car. So in that respect probably best left in twin turbo form because thats what a collector would look for I'd imagine. Although single turbo is a great experience, and something to consider if you can afford to do it properly. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted July 6, 2016 Share Posted July 6, 2016 Single is generally between 6-10k deppending if your going to do the workn your self?. ID go singleton future prof the car or big twins SRD do a great single kit. Remember when going single you need the other upgrades for fuel system and stand alone ECU Link to comment Share on other sites More sharing options...
drifter Posted July 6, 2016 Author Share Posted July 6, 2016 Any 1 have the problem torque kit The year say u can use standard 550cc injectors Standard cams and intercooler And ecu close to 500 bhp Link to comment Share on other sites More sharing options...
drifter Posted July 6, 2016 Author Share Posted July 6, 2016 Pro torque kit Link to comment Share on other sites More sharing options...
Frank Bullitt Posted July 6, 2016 Share Posted July 6, 2016 (edited) You can't go single safely on the stock ECU. If you don't have the 10-15K it will cost you to go single, stay TT. Edited July 6, 2016 by Frank Bullitt Spelling. (see edit history) Link to comment Share on other sites More sharing options...
Big Mark Posted July 6, 2016 Share Posted July 6, 2016 Berg has just fitted the PHR Street Torque kit and is running on a stock ECU with no issues and a 1 bar spring in the Waste Gate until he changes the ECU. If/when I go single I reckon I'll be going for the same kit. Oh and kit fitted perfectly and included absolutely everything including blanking plugs and caps. I think it's $2560 from MVP (who are cheaper than direct from PHR) Link to comment Share on other sites More sharing options...
Frank Bullitt Posted July 6, 2016 Share Posted July 6, 2016 Surely fuelling will be all over the place using the stock ECU. How long is he intending to stay single for before adding the standalone ECU? I am guessing not very long... Link to comment Share on other sites More sharing options...
berg Posted July 6, 2016 Share Posted July 6, 2016 (edited) Surely fuelling will be all over the place using the stock ECU. How long is he intending to stay single for before adding the standalone ECU? I am guessing not very long... Not very long at all But fuelling is absolutely fine, readings are barely any different to when it was on twins, its ever so slightly richer at WOT, wideband gauge reads low 12s/high 11's Lots of people have done it in the past, some permanent and have no intentions of changing to a standalone so i dont know why so many people say you have to baby it and run no boost at all I will admit i tried the 1bar spring expecting it to be lean top end and would have changed to a 0.6bar to be safe but its fine Also £20k to do a single right??? thats rubbish unless you follow suit and go built engine and syvecs All in including ecu and mapping mine will owe me under £5k, if your going from a stock car then expect a bit more, ive come from bpu so exhaust, intercooler etc i already had Edited July 6, 2016 by berg (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted July 6, 2016 Share Posted July 6, 2016 Another option is Munro setup http://www.munroracingturbochargers.com.au/ Link to comment Share on other sites More sharing options...
drifter Posted July 6, 2016 Author Share Posted July 6, 2016 Not very long at all But fuelling is absolutely fine, readings are barely any different to when it was on twins, its ever so slightly richer at WOT, wideband gauge reads low 12s/high 11's Lots of people have done it in the past, some permanent and have no intentions of changing to a standalone so i dont know why so many people say you have to baby it and run no boost at all I will admit i tried the 1bar spring expecting it to be lean top end and would have changed to a 0.6bar to be safe but its fine Also £20k to do a single right??? thats rubbish unless you follow suit and go built engine and syvecs All in including ecu and mapping mine will owe me under £5k, if your going from a stock car then expect a bit more, ive come from bpu so exhaust, intercooler etc i already had Is this kit laggy compare to standard and what turbo have u Link to comment Share on other sites More sharing options...
