Parm_93 Posted July 4, 2016 Share Posted July 4, 2016 Hi guys, So I'm doing a NA-TT swap, blah blah blah... Long story short, I have a JDM 6 speed engine loom, however there's no connector for the PAS solenoid on the loom. It doesn't look it has been cut and there is no connectors hanging loose , did any of the 6 speeds come without the solenoid or is something wrong here? Is it important or will I be alright without it? Thanks, Parm Quote Link to comment Share on other sites More sharing options...
Parm_93 Posted July 6, 2016 Author Share Posted July 6, 2016 No-one have any idea on this? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted July 7, 2016 Share Posted July 7, 2016 Should be there if the engine is from a Supra. Even the 1uz loom has it. Should have a green/black stripe wire and green/red stripe wire. Quote Link to comment Share on other sites More sharing options...
Parm_93 Posted July 7, 2016 Author Share Posted July 7, 2016 Should be there if the engine is from a Supra. Even the 1uz loom has it. Should have a green/black stripe wire and green/red stripe wire. Does the connector sit on the intake manifold side, or where the lambda sensor connector comes out? Also if I don't run with it connected, what difference will it make? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted July 7, 2016 Share Posted July 7, 2016 I have a feeling it comes out on the inlet side and is routed under the front of the engine and then along the block. I'll be with my supe on Saturday, I'll have a look. Quote Link to comment Share on other sites More sharing options...
