kevin smith Posted July 3, 2016 Share Posted July 3, 2016 Hi guys my Jap import had a problem with the engine warning lights coming on when i booted it, and when it hit 80mph and the gearbox would get confused and the OD light would flash on and off. I got advice from you, to change the KPH to MPH converter, i have done this and the gearbox is changing gear very nicely now and the OD light has stopped flashing. But when i booted it the engine warning lights came on again, any ideas or help would be very much appreciated. Thanks Kevin. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted July 3, 2016 Share Posted July 3, 2016 what light is it? could be low brake fluid, common problem if it is on the minimum that when you put your foot down the fluid sloshs to one side and the light comes on briefly. Also have you checked for error codes? Quote Link to comment Share on other sites More sharing options...
kevin smith Posted July 3, 2016 Author Share Posted July 3, 2016 Thanks rip, the brake fluid is fine. It's the main warning light/ handbrake light and the little engine shape light on the right hand side top of the dash above the clock cluster. Ps i have no way of checking error codes. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted July 3, 2016 Share Posted July 3, 2016 Thanks rip, the brake fluid is fine. It's the main warning light/ handbrake light and the little engine shape light on the right hand side top of the dash above the clock cluster. Ps i have no way of checking error codes. you can check the error codes at home by bridging the diag ports with a paper clip then count the number of flashes on the dash. Search for paper clip test and go from there Quote Link to comment Share on other sites More sharing options...
Nic Posted July 3, 2016 Share Posted July 3, 2016 Ps i have no way of checking error codes. Very easy to do http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes Quote Link to comment Share on other sites More sharing options...
kevin smith Posted July 3, 2016 Author Share Posted July 3, 2016 Thanks guys will give it a go. Quote Link to comment Share on other sites More sharing options...
mellonman Posted July 4, 2016 Share Posted July 4, 2016 I always thought that that warning light was for knock . What mods do you have ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 4, 2016 Share Posted July 4, 2016 It's for umpteen different things, hence why you need to read what codes it's beefing about Quote Link to comment Share on other sites More sharing options...
kevin smith Posted July 4, 2016 Author Share Posted July 4, 2016 only dropped one cat and a new exhaust. but was doing it before these were done?. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 4, 2016 Share Posted July 4, 2016 Read the codes, it's the only way of finding out. 5 minute job, just need a bit of wire or a bare metal paper clip. Quote Link to comment Share on other sites More sharing options...
